looking for postform top from direct supplier. needing it for my cabinet. cos the quote i got from my contractor is slightly too expensive. can anyone direct me where to buy that?
Postform top's normally cannot be bought, they are fabricated with laminate by factory compression. So it is only made according to the length of your cabinet. If you were finding your postform top too expensive, you can look around for quotes on solid surface tops, and if the solid surface quote is not too much more from what your contractor quoted, you can always use solis surface instead.
IMHO, I find that solid surface would be a better material to use, as postform is at the end of the day still laminate over wood, so the wear and tear compared to solid surface will be faster.
