Rate My Quote - 5room Resale $28,888
Hi all thanks in advance for your comments. Any advice is appreciated.
Professional Service
01) 1 Years Warranty on Masonry work
02) 1 Years Warranty on Carpentry work
03) Budget Planning
04) Design Planning
05) Space planning
06) Furniture Layout planning
07) Material & colour Proposal
08) Project Management
09) Professional Site Supervision
10) Perspective Drawing
11) Apply HDB Permit FOC
Hacking Works
Living area
01) Labour to hack living and dining hall floor tiles
Kitchen area
01) Labour to hack Kitchen Floor and Wall Tiles
02) Labour to hack kitchen cabinet
03) Labour to hack cabinet base
04) Labour to hack Fridge base
05) Labour to hack Washing machine base
06) Labour to dismantle existing water pipe
2 Bathroom area
01) Labour to hack 2 bathroom floor and wall Tiles
02) labour to hack 2 bath room sanitary ware
03) Labour to dismantle 2 bath room water pipe
04) Labour to hack 2 bath room door
Bedrooms area
01) Labour to hack 3 bedroom existing cornices Amount : $2,600.00
Masonry Works (Exclude Tiles)
Living hall area
01) To supply labour to lay marble flooring **** and dining hall [ Marble and polish by owner]
2 Bath room area
01) To supply and lay 2 bathroom Heavy Duty Homogenous floor tiles [within $3.00]
02) To supply and lay 2 bathroom designer wall tiles
Kitchen area
01) To supply labour to lay kitchen wall tiles [within $3.00]
02) To supply labour to lay kitchen Heavy Duty Homogenous floor tiles.[within$3.00]
03) To construct cabinet base, fridge base and washing base Amount : $7,650.00
Carpentry Works
Living area
01) To supply and install with L 6ft feature wall **** hall household shelter come with swing door using laminate finishing Amount : $900.00
Bedrooms area
01) To supply and lay parquet flooring at 3 bedroom [ size 2"x 8" ] Amount : $3,500.00
Bathrooms area
01) To supply and install 2 vanity cabinet at 2 bath room using laminate finishing
02) To supply and install 2 vanity solid surfcae top
03) To supply and install 2 vanity mirror Amount : $1,300.00
Plumbing Works [Exclude Sanitary ware ]
01) To run inlet Stainless steel pipe for kitchen and 2 bathroom sink
02) To run inlet stainless steel Pipe for washing machine
03) To run 2 hot pipe at 2 shower set
04) To run drainage PVC pipe for kitchen, and 2 bathroom sink
05) To run drainage PVC pipe for washing machine
06) Labour to connect pipe at kitchen sink
07) Labour to install 2 toilet bowl.
08) Labour to install wall mounted Wash Basin at 2 bathroom.
09) Labour to install kitchen sink
10) Labour to install instant tank heater at master bathroom
11) Labour to install 2 bath room accessories Amount : $1,500.00
Painting Works
01) Paint whole unit wall and ceiling. [ ICI / Nippon ]
02) Paint whole unit water pipe.
03) Paint whole all doors and frame
04) Paint main Gate Amount : $1,200.00
Aluminium door
01) To supply and install 02 PD door at bath room come with PVC finishing Amount : $700.00
Miscellaneous
01a) Load and unload goods
b) Arrange Skip Tank
c) Cardboard protection
d) Supply sand and building material
e) Water proof screed and waterproofing membrane upturned up 150mm
against the wall at 3 bathroom . [ 2 layer ]
f) Cleaning and acid wash Amount : $2,500.00
Promotion Items
Promotion for first 20 set while stock last
01) To supply and install WITHIN L12ft low Designer kitchen cabinet completed with: $1,188.00
a) Laminate finishing
b) Solid door with ABS trimming
c) 4 pc drawer
d) Cutlery tray
e) Labour Install cooker Hood and Hob
j) To supply and install within L12ft solid surface kitchen top $888.00
Total Package : $23,926.00
Additional Items Package B
01) To supply and install 10mm tempered frameless clear glass sliding at kitchen entrance [ 3x 7ft ]
02) To supply and install sliding door shower screen at master bathroom come with white aluminium
frame and clear glass finishing
03) To supply and install 10mm tempered glass shower screen at common bathroom come with one
fixed panel and swing glass door
04) To construct heavy duty gypsum board partition feature wall **** hall and master room T.V area
come with paint finishing
05) To supply and install solid plywood backing at T.V area
06) To box up sewage pipe at 2 bath room using waterprooft plaster board come with paint finishing
07) To supply and install false ceiling **** hall
08) To supply and install 2 side false ceiling at master room
Total Amount : $4,962.00
Grand Total : $28,888.00
Painting Works
CHEAP!
j) To supply and install within L12ft solid surface kitchen top $888.00 (depend on material)
if u break down the price,we can see clearer pic.
Painting Works
CHEAP!
Are there any important items missing besides electrical? Intending to put rain shower in both bathrooms
I'm also doing almost the same works as you. Quote also almost similar. 1 question tho, what about electrical? Seeing that you have false ceiling, rewiring/adding points?
ID tells me very personal...so i should set aside 1-2K for tat..he say wont amount to much
can post ur quote here to compare?
Will pm you.
thanks SFF received your quote. Looks pretty ok to me.
Anybody else have comments or advice? Is anything major missing besides electrical?
