Stone23
Need Sincere Advise... Pls Help
Hi Folks,
I just receive a quotation from a renovation contractor. Please kindly assist me on the costs and suggestions or ideas on my renovation.
Type of Flat: 4A, 104sqm (abt 20+ yrs old flat) so basically need to overhual the whole house.
Please advise.
A. Dismantle/Demolition and Disposal
1. Supply labour and tools to hack off existing floor tiles, wall tiles and clear debris ~$2,600
B. Living room, 3 bedrooms & 1 storage room
1. Supply & lay 600x600mm China homogenous tiles c/w skirting finish ~$4,300
2. Supply & install sliding aluminum window to all window ~$2,200
3. Supply & install 2. nos of aluminum grills to all window ~$1,280
4. Supply & install 1 to 3 air-con (Normal Panasonic) ~$1,950
5. Supply and install normal cornice to whole house c/w some false ceiling ~$950
6. Supply and install 1 no. of wrought iron gate ~$450
7. Supply and install 3 nos. of solid design door for 3 bedrooms ~$840
8. Supply & install 1 no. of solid design main door ~$420
9. Supply & install full height laminated wardrobe in one of the common room c/w ~$1,050
trimming (5ft)
10. Supply & install full height laminated wardrobe in mater bedroom c/w ABS trimming ~$2,100
(10ft) in mater bedroom
11. Supply and install full height laminated partition c/w laminated sliding door in master ~$2,200
bedroom
12. Supply and install laminated feature wall in living room (8ft) ~$1,380
13. Supply & install laminated TV console (6ft) ~$720
C. Kitchen
1. Supply & constuct kitchen cabinet base ~$200
2. Supply labour and materials to plaster wall ~$700
(Do not intend to have intense cooking at home so not considering have wall tiles
for the whole kitchen area. So instead of having full area of wall tiles, we will seek
for cheaper way which is to plaster half of the kitchen wall)
3. Supply & lay ceramic floor tiles ~$1,400
4. Supply & lay water proofing ~$200
5. Supply & install upper and lower laminated kitchen cabinet with ABS trimming finishing ~$2,400
(20ft by design) c/w laminated works top
{Is it advisable to have laminated works top or solid top????}
6. Supply & construct kitchen sink support c/w tiles finish (6ft) ~$680
7. Supply & install 6mm red temper glass in between up and down cabinet (8ft) ~$420
8. Supply & install wall tiles at the window area and debris chute area ~$600
9. Supply & install 1 no of S/s debris chute ~$160
D. Toilets
1. Supply labour to install 2 nos. of toilet bowl ~$200
2. Supply labour to install 2 nos. of basin ~$120
3. Supply & lay ceramic floor tiles ~$900
4. Supply & lay ceramic wall tiles up to ceiling height ~$2,800
5. Supply and lay water proofing ~$300
6. Supply & install 1 no. of aluminum bi-fold door in common toilet ~$180
7. Supply labour & materials to alter existing squat WC to sitting WC ~$100
8. Supply labour & materials to box up exisiting sewage pipe ~$600
E. Others
1. Painting of whole house using ICI paints c/w oil best coated ~$1,250
2. Supply & install stainless steel pipe for the whole house (hot & cold) ~$950
3. Rewiring for the whole house including fix lights (EST only) ~$2,800
Total: $39,400
Welcome all advises, suggestions, ideas & opinions!!!!
TQ! TQ!
Ask them
1. How many coat
2. How many colour
3. Include paint door frame and main door
HI..
Maybe you can compare with my qoute My renovation qoute
Mine is consider expensive for 84sqm flat.. but my s/s rubbish chute was given free
Take note of the following :
* Electrical Points
* Your toilets, they only supply labour.. seems like you have to make yr own purchase on the wc, vanity and stuffs
* Supply & construct kitchen sink support c/w tiles finish (6ft) ~$680 (MIne was SGD300)
for others.. u can compare with my reno qoutes..
cheers!
Hi Folks,
Please advise.
trimming (5ft)
bedroom
C. Kitchen
D. Toilets
E. Others
Total: $39,400
TQ! TQ!
WOW!,
4 rm only need 39k=??????? & only half a kitchen wall -.-, window abit expensive, kitchen cabinet is better with a solid surface top around 70-75 per feet run, its better to use aluminium sliding door for wardrobe just a bit more only, painting is 1250, make sure he do a nice job with such a price( 6 colour at least )
Hi Folks,
Please advise.
trimming (5ft)
bedroom
C. Kitchen
D. Toilets
E. Others
Total: $39,400
TQ! TQ!
1) cabinets is quite reasonable ... swingdoor i supposed.
2) kitchen cabinet can try to ask for $100/ft
3) boxing up of sewage pipe is $600 ? what materials ?
4)ICI paint for 4 rm = try $1100
5)s/s pipes = $700
6) electrical .... u can prepare $3500
Hi Folks,
Please advise.
trimming (5ft)
bedroom
C. Kitchen
D. Toilets
E. Others
Total: $39,400
TQ! TQ!
