Aerogaz Or Ef Hob Anyone?
Hi forummers
Due to limited table top space, I can only take a hob with cut-out size not bigger than 65cm in width.
This leaves me with limited choices.
From fttw, I was introduced to AEROGAZ and the website sells at $290 for a GLASS hob with 4 burners (in a 2 by 2 layout)
I will only use 1 burner at a time as I am not capable to multi-task while cooking :P
But seems very few retailors carry this brand.
Those that do also say AEROGAZ does not sell well....not sure if it is due to commission scheme not being attractive or what.
But they also do not hear any complaints.
What other brands and models would you recommend?
BORSCH, Brandt etc are too expensive for me :bangwall:
I saw EF hob.
Was told it is a sister company of ELBA, an established italian brand.
The ss hob with 3 burners (in a triangle layout) cost $360 in MEGA DISCOUNT STORE before discount.
This hob has cast iron.
But I am hoping to buy a glass hob with at least 3 burners for less than $400.
Hope you all can help me.
  • 1 year later...
I currently have EF hob & hood. Dun like it! The stainless steel gets burned easily. Then any cooking stain if left for 1-day, becomes really hard to clean off especially around the burner area. Now the rim is all black. aargghh. Then the hood... the lighting cover cannot remove to clean. Need to unscrew. Lousy design. So the lighting cover is now filled with oil and soot. Yucks! Will not get EF brand ever after this experience.
