My New Home @ Cck Ea
I just bought a resale EA at CCK. This is the original floorplan. floorplan.png
My mission here:
to create another bedroom from the current layout.
build TV feature wall
relocate the master bathroom toilet door as I want to have shower screen for both bathroom.
I have two plans. Plan A required lot of hacking since we also need to get rid of the entire store room and move it to kitchen.
Plan B required minimum hacking as we simply move the toilet door close to the center of the bathroom. In this case the position of the bed as well as door direction is also taken care.
I am running out of ideas, apart from this I was thinking of just convert the study room to a bedroom and simply create study corner in the existing living room but I don't want the TV noise to disturb my son study.
Any comment is welcome here
Like that u waste the space from the 1st balcony. The small walkway leading to the living room. Hw abt taking away the balcony between bedroom 2 and 3?
congrats on the purchase! :)
For the master bedroom... I do think Plan A looks nicer but Plan B's a lot more practical. I did think... well if you want to save some money and don't mind the squeeze.. For the MBR toilet, have a tempered glass door that swings outwards / slides with track on the outside (at the current location of the toilet door. Then make an L shaped 1m by 1m shower stall just next to the door and shift the sink to opposite the toilet bowl *staggered to the empty side*. Might look kinda odd and squeezy but will prolly save some money.
As for the study and son's bedroom, I'll do this...
Move the wall to make the kitchen smaller.. (cos I'll prefer a small kitchen and big hall, then having an odd hall and a big kitchen...) then partition the ultra big bedroom into two.. needn't be a wall partition.. can be made by anything like cabinets or dividers/bookshelf...
So in other words.. I reckon I'll save on the thing in the MBR/store/toilet... to do this on the study/bedroom/kitchen... cos I'll end up with a bigger hall. <---- which can include a nice dining area.
but that's just imo. :) a big hall is always impt to my family. haha
I still prefer a dedicated study area. Here my new plan C. I will relocate the study to the living room. This will save some space for the Living area.
I just get two quote from two different ID firms. One is already out as the guy miss out lot of items.. Please comment on the following quote.
DEMOLITION WORKS
to supply labour & hack full high wall tile at both toilet 450
to supply labour & hack existing floor tile for kitchen & both toilet 300
to supply labour & demolish existing toilet accessories & sanitory ware at both toilet 100
to supply labour & creative new door entrance at master toilet 180
to supply labour & remove existing laminate flooring at master bedroom 150
to supply labour & remove existing kitchen cabinet 180
to supply labour & remove wardrobe at master room with disposal 180
to supply labour & hack existing concrete sink/slove support 100
to supply labour & demolish existing wall between store & master bedroom 280
Miscellaneous works
to supply & paint of wall & celling for whole house include all expose piping (nippon paint) 1150
to supply & paint existing door frame 100
to apply for skip tank permit 150
to haulage material to unit c/w debris disposal 350
to supply labour for general cleaning whole house include acid cleaning for floor wall & windows 180
to supply & protect flooring **** & study room with cardboard 200
PLUMING WORKS
to supply & run stainless steel pipe at kitchen & both toilet 650
to supply & run 01 hand spary point for master and common toilet 60
to supply labour to joint in/out let pipe for kitchen sink 150
to supply labour to joint in/out let pipe for washing machine 30
to supply labour to install 1 no standard wash basin at master and common toilet 120
to supply labour to install 1 no standard siting bowl at master and common toilet 240
to supply labour to install toilet accessories at master and common toilet 70
to supply labor to install heater 90
CELLING WORKS
to supply & install L-Box cornice **** 550
to supply & elect 68ft partition at kitchen for store room 450
to supply & elect 162 sqft partition **** for bedroom 534
to supply & conceal existing door at master bedroom with plaster board 200
DOOR WORKS
to supply & install 1 pcs classic door c/w hinge & lock set 170
to supply & install 1 pcs wooden door frame 180
MASONRY WORKS
to supply & plaster wall at kitchen 1500
to supply & lay ceramic wall tile to ceiling high at both toilet 2000
to supply & lay matt finish homogenous tile for kitchen & both toilet 1150
to supply & apply water proofing membrane for kitchen & both toilet 180
to supply & construct 50mm fridge base with tile finish 100
to supply & construct 50mm washing machine with tilet finish 100
to supply & construct shower curb at master toilet with tile finish 80
to supply & construct shower curb at common toilet with tile finish 80
to supply & construct 50mm cabinet base with tile skirting 250
to supply & make smooth damage edge after demolish wall at master bedroom 180
to supply & conceal existing toilet entrance with hollow block & one side cement finish one side tile finish 280
LAMINATE FLOORING WORK
to supply & install laminate flooring at master bedroom c/w skirting 660
CARPENTRY WORKS
to supply & fabricate 4ft half high shoes cabinet with laminate finish 480
to supply & install 3 ft dressing table with laminate finish 330
to supply & install 3 x 5 ft mirror at master bedroom 180
to supply & fabricate 8.5 ft designed full high wardrobe with glass sliding door aluminium frame & laminate finish 2040
to supply & fabricate 12 ft top hung book shelf with laminate finish 1200
to supply & fabricate 12 ft suspended study table with laminate finish 1200
to supply & fabricate 26 ft solid plywood kitchen cabinet with laminate finish 2 glass door, 4 drawer, 1 cutlery tray & 1 stainless steel disk tray 2470
to supply & install 12 ft solid surface work top with 3 inch profile 780
to supply & install glass backing between kitchen cabinet 450
to supply & fabricate 7 ft designed suspended TV console with laminate finish **** 770
to supply & fabricate 7 ft designed feature wall with laminate finish 1120
