Our 1st Home: 4-rm Resale At Bt Panjang
Dear all, I have included the quotation below and welcome any comments that you can offer me. Especially whether any items I can further bargain on. Thanks in advance :)
These are the works included in the quote:
Demolition works
1. To supply labour & hack existing floor tile c/w skirting **** room & dinning
2. To supply labour & hack existing floor tile c/w skirting at all rooms
3. To supply labour & hack wall tile at kitchen & both toilets
4. To supply labour & hack existing floor tile for kitchen & both toilet
5. To supply labour & demolish existing toilet accessories & sanitary ware
6. To supply labour & remove existing kitchen cabinet with disposal.
Miscellaneous works
1. To supply & paint of wall & ceiling for whole house include all exposed piping
2. To supply & paint existing door frame
3. To supply labour for general cleaning whole house include acid cleaning for floor, wall & window.
4. To haulage material to unit c/w debris disposal
Ceiling works
nil
Masonry works
1. To supply & lay 60x60 polish homogenous tile for living & dining
2. To supply & lay 60x60 polish homogenous tile for all bedrooms
3. To supply & lay polish homogenous tile skirting for whole house
4. To supply & lay ceramic wall tile to ceiling height at kitchen
5. To supply & lay ceramic wall tile to ceiling height at both toilets
6. To supply & lay matt finish homogenous tile for kitchen & both toilets
7. To supply & apply water proofing membrane for kitchen & both toilet flooring
8. To supply & construct 50mm fridge base with tile finish
9. To supply & construct 50mm washing machine base with tile finish
10. To supply & construct 50mm cabinet base with tile skirting
11. To supply & construct shower curb at master toilet with tile finish
Carpentry works at master bedroom
1. To supply & fabricate 6ft designed full height wardrobe c/w sliding door & laminate finish $1380
Plumbing works
1. To supply & run stainless steel pipe at kitchen & both toilets
2. To supply labour to joint in/outlet pipe for kitchen sink
3. To supply labour to joint in/outlet pipe for washing machine
4. To supply & install 02 standard wash basin at master & common toilets
5. To supply & install 02 standard sitting bowl c/w flushing tank at master & common toilets
6. To provide labour to install toilet accessories at master & common toilets
7. To supply & run hand spray point at master & common toilets
8. To provide labour to install heater
Carpentary Works at Kitchen
To supply & fabricate 20ft solid plywood kitchen cabinet c/w laminate finish, 2 glass door, 4 drawers & 2 cutlery tray $1600
To supply & install 10ft solid surface work top with 3 inch profile $580
Aluminium / Wrought Works
To supply & install aluminium bi-fold door at master & common toilets c/w wpc & pvc board
And here is the price breakdown
Living & Bedrooms $8480
Kitchen & both Toilets $9950
Kitchen cabinet $2180
Aluminium / Wrought works $3251
Total initial price comes to $23861
After remove unwanted ceiling cornice and false ceiling and other miscellaneous items, adding on re-wire of whole unit, price reduced to $21888
Good deal?
Looks very reasonable to me!!! Welcome to RT
Thank you :) Hope ID is reliable :)
I got a quote for my inbuilt stuff, also go up to $20k... no hacking involved ok! so I should think yours is a good price. :)
