Diy - Glass Decal For Sliding Glass Door
We are expecting arrival of the below Glass Decal and need some tips on how to go about as the instructions were all in korean.
Had anyone attempted to DIY the glass doors?
We would appreciate any advice. Thanks in advance ! =D
Questions :
1. which side of the glass to work on
2. what to buy?
3. do we use penknife to cut?
44822_429139607331_658877331_4834301_384
45000_429139777331_658877331_4834303_171
45000_429139782331_658877331_4834304_552
Edited by velv
Based on the pictures I would imagine the instructions to be;
1. Measure the size of the window / door and allow an overlap of 5-10cm in both height and width. Cut the decal to rough size.
2. Wash the window with window cleaner to remove dirt or grease.
3. Place the decal on the window starting from one corner and slowly working down.
4. Use the scraper to push any bubbles to the edge of the decal
5. Use a pin to prick and bubbles that cannot be moved and smooth the surface.
6. Use a straight edge (metal ruler or the like) and a craft / Stanley knife to trim the excess edge of the decal.
Hope this helps.
RB
Hope this helps.
RB
I wish to add in 1 more step in addition to the above step 3. (This step is shown in picture no. 2) This will make your work easier. Spray soap water onto the glass. This would allow you to adjust the decal. Thereafter use a scraper or credit card to scrap out the water.
Edited by northguysg
Yup. Definitely must add soap water to the glass door before applying the decal! After scrapping out the water and bubbles, just leave it to dry : )
  • 2 months later...
148329_465678072331_658877331_5506408_55
after a few months hubby finally put it up today..
however we can see shadow behind when there is light.. any suggestion to perhaps improve it? curtains?
  • 3 weeks later...
Hi Velv, Looks gd!!
May I know where u buy the decal and how much psm?
Thks...
