matrix0405
How To Remove Window Grills?
I have sliding window grills for my windows, which i wld like to remove some of them for a better view. I tried to lift the grills out of its housing brackets but there was not enough clearance for me to just take it out. Can these grills be taken out DIY? Is there somethingelse i need to do before lifting the grills out? Thanks.
of coz u can't lift the grills out of the bracket, otherwise thefts can also do the same, defeats the purpose. :sport-smiley-018:
they'll slot in the the grill, then either rivet or screw-in at the corners. look for plastic covers.
Need to remove side housing bracket, slide the grills out. Before that, unscrew & remove whole frame or housing bracket from window..
Edited by bepgof
