Aircon-which Brand For 4 Bedroom, Living And Dining?
Harlo,
Anyone know which brand or type I should use if I need aircon in 4 rooms, 1 living and 1 dining? Totally no idea. Is it must buy both system 2 and 3 together? I heard Mitsubishi inverter is good but not sure whether suitable. Got any Mitsubishi system 5?
  • 4 months later...
How far apart is your living and dining? If its not too far away, then you may want to consider getting just 1 unit with a higher BTU for Living/Dining. The rest of the rooms can be a system 3. Mitsu Elec is one of the more established brands along with Daikin. My Mitsu Elec Inverter unit is a tad noiser than my folks Daikin. So you may want to check out Daikin to make the comparison.
I am using Panasonic non inverter one and so far so good no problem ;)
Harlo,
Yes currently have up to 10 indoor units then you must choose for VRV system or panasonic in malaysia already launch the FS multi VRF system.
Only not suitable for HDB, the Amp is limit to control at 8.5A :)
http://www.panasonic.com.my/web/productsso...ditioningsystem
http://www.daikin.com.sg/products.asp?series=c1
http://www.mitsubishielectric.com.sg/produ...erant-flow.html
Edited by kimsim
