Renovation Quote For Resale 3 Room
Hi forumers,
i am new here and has been logging on to renotalk almost everyday since we went for our 1st appt. i must say its a fantastic forum and many good advices given by the friends who already got their house done.
Anyway, we will be meeting our contractor this weekend to discuss the final details and charges. By the way, i got to know this contractor from one of the forumers here who had got their house done by the ID.
Would appreciate if you can give me some advice to see which are the items i can further negotiate with my contractor.
Below is his quotation to us. Hope to get some favourable replies from you friends. Thanks.
We are pleasure to quote u for the above unit renovation works:
HACKING WORKS:
1To dsimantle ofr existing kitchen cabinet and wardrobe.
$200
2To hack off existing bathroom /w.c floor tiles.
$150
3To hack off existing bathroom/w.c wall tiles.
$350
4To hack off existing kitchen floor tiles.
$200
5To hack off existing kitchen wall tiles.
$350
6To hack off existing livinghall/02 bedroom floor tiles.
$600
7To hack off existing 02 bedroom door frame.
$160
To hack off existing wall between living hall and kitchen area.
$250
9Clear all debris off site.
$250
Total
$2,300
WET WORKS:
1To supply & 300mm x 300mm homogeneoues floor tiles for bathroom/w.c c/w
$800
waterproofing.
2To supply & lay 300mm x 600mm ceramic wall tiles up to ceiling high for
$1,900
bathroom/w.c .
3To supply & lay 300mm x 300mm homogeneoues floor tiles for kitchen c/w
$800
waterproofing.
4To supply & lay 300m x 600mm ceramic wall tiles up to ceiling high for
$2,500
kitchen area.
5To top up kitchen and living hall area with 2" foam for extending living hall
$400
6To supply & install 02 wooden door frame.
$480
7To supply & install new stainlesssteel bin chute hopper.
$200
8To supply & lay 600mm x 600mm homogeneoues floor tiles for living hall and
$3,700
02 bedroom c/w skirting.
9To construct 63mm hollow block support wall for kitchen area.
$300
10To construct 50mm cabinet base/fridge base and washing basin base.
$350
Total
$11,430
PLUMBING WORKS:
1Whole unit change to stainlesssteel piping.
$480
2To supply labour to install w.c
$85
3To supply labour to install 01 washing basin.
$65
4To supply labour to install instant heater.
$35
5To supply labour to instal sink and connect inlet.
$85
Total
$750
ALUMINUM WORKS:
1To supply & install 02 nos. of alum bi-fold pvc door for bathroom/w.c area.
$400
2To supply & install low panel sliding window and top panel with adjustable
$580
ouver window for bedroom 2 and living hall.
3To supply & install wrought iron window grilles c/w lock for living hall and
$600
bedroom 2.
4To supply & install 01 set of wrought iron main gate.
$500
5To supply & install 02 set of alum louver window for bathroom and w.c area.
$500
Total
$2,580
WOODEN WORKS;
1To supply & install 02 set of new venneer door c/w lock set for 02 bedroom.
$580
2To supply & install 01 set of solid nyatoh main door c/w lock set.
$500
Total
$1,080
ELECTRICAL WORKS:
1Whole unit re-wiring c/w new socket point /power point/T.V/Tel/SCV point
$2,100
and new DB box and inculding install all lighting.
PAINTING WORKS:
1Whole unit paint ICI/NIPPON emuslion paint inculding all pvc piping/door and
$1,000
door frame.
CARPENTRY WORKS:
1To supply & design laminated solid plywood top/bottom kitchen cabinet c/w
$2,750
disctray and ABS trimming/
(15ft)
2To supply & install solid surface kitchen work top for new kitchen cabinet.
$1,125
3To supply & design laminated solid plywood wardrobe with sliding alum
$1,690
foster glass for master room.
(6.5ft)
4To supply & design laminated solid plywood wardrobe with sliding alum
$1,690
foster glass for bedroom 1.
(6.5ft)
5To supply & design rotating t.v console up to ceiling high with drawer for
$1,650
living hall area.
6To supply & design laminated solid plywood prayer table up to ceiling high.
$1,288
Total
$8,543
CEILING WORKS:
1To supply & design L box for living hall area.
$580
2To supply & design flase ceiling for dining area.
$300
3To supply & design L box for 02 bedroom.
$800
Total
$1,680
OTHERS WORKS:
1To supply labour to install whole unit accessories for bathrom/w.c area.
FOC
2Whole unit chemical washing.
FOC
GRAND TOTAL
$28,500
Hi forumers,
HACKING WORKS:
$200
$150
$350
$200
$350
$600
$160
$250
$250
Total
$2,300
WET WORKS:
$800
waterproofing.
$1,900
bathroom/w.c .
$800
waterproofing.
$2,500
kitchen area.
$400
$480
$200
$3,700
$300
$350
Total
$11,430
PLUMBING WORKS:
$480
$85
$65
$35
$85
Total
$750
ALUMINUM WORKS:
$400
$580
$600
bedroom 2.
$500
$500
Total
$2,580
WOODEN WORKS;
$580
$500
Total
$1,080
ELECTRICAL WORKS:
$2,100
PAINTING WORKS:
$1,000
door frame.
CARPENTRY WORKS:
$2,750
(15ft)
$1,125
$1,690
(6.5ft)
$1,690
(6.5ft)
$1,650
living hall area.
$1,288
Total
$8,543
CEILING WORKS:
$580
$300
$800
Total
$1,680
OTHERS WORKS:
FOC
FOC
GRAND TOTAL
$28,500
Your quotation seems to be a little on the high side, maybe you should still compare with a few more others first.
i was quoted 21k for 3 room resale, PM me if you need reno contact. :)
Refer to your quote.........
Regards,
Hi forumers,
HACKING WORKS:
1To dismantle off existing kitchen cabinet and wardrobe.
$200
$150
$350
$200
$350
$550
$80 ($40 each)
$150
$250
Total
WET WORKS:
waterproofing. $650
bathroom/w.c . $1,650
waterproofing. $780
kitchen area. $2,350
$250
$320 ($160 each)
7To supply & install new stainless steel bin chute hopper.
$160
02 bedroom c/w skirting. $3,350
$300 (depend on the length)
$290 (Cabinet Base - $150 + Fridge Base - $70 + Washing Machine Base - $70)
Total
PLUMBING WORKS:
$480
$80
$45
$35
$70
Total
ALUMINUM WORKS:
$300 ($150 each)
$580
Louver window for bedroom 2 and living hall.
bedroom 2. $600
$380
$320 ($160 each)
Total
WOODEN WORKS;
$480 ($240 each)
$420 for Solid Nyatoh. and for Veneer at main door $550
Total
ELECTRICAL WORKS:
and new DB box and inculding install all lighting. $2,100 (Depend how many points you install between $1,650 - $2,500)
PAINTING WORKS:
door frame. $1,000 (same price using ICI Dulux All / Nippon Wash and Wear)
CARPENTRY WORKS:
disH tray and ABS trimming/ $2,750 ($110 per feet if 7.5ft top and 7.5ft bottom = 15ft x $110 total = $1650)
(15ft)
$1,125 How long is your top ? ($60 per foot run)
foster glass for master room. $1,625
(6.5ft)
foster glass for bedroom 1. $1,625
(6.5ft)
living hall area. $1,650
$1,288 (What is the length)
Total
CEILING WORKS:
$450
$300
$700
Total
OTHERS WORKS:
FOC
FOC
NO GST / HIDDEN COST
GRAND TOTAL
Edited by blackwhite.sg
Regards,
Hi forumers,
HACKING WORKS:
$200
$150
$350
$200
$350
$550
$80 ($40 each)
$150
$250
Total
WET WORKS:
waterproofing. $650
waterproofing. $780
$250
$320 ($160 each)
$160
Total
PLUMBING WORKS:
$480
$80
$45
$35
$70
Total
ALUMINUM WORKS:
$300 ($150 each)
$580
bedroom 2. $600
$380
$320 ($160 each)
Total
WOODEN WORKS;
$480 ($240 each)
Total
ELECTRICAL WORKS:
PAINTING WORKS:
CARPENTRY WORKS:
(15ft)
(6.5ft)
(6.5ft)
Total
CEILING WORKS:
$450
$300
$700
Total
OTHERS WORKS:
FOC
FOC
GRAND TOTAL
