Methtical
Need Help In Cove Lights
Need help in cove RGB leds lights, how many led strips do i have to install for my cove lights, double or single strips?
Wat the dimension of your cove lighting?
I also need help in installing the rgb cove lights ..
am wondering if its for cove light should i get the adapter that plugs into a electrical outlet or a power supply that connects to the lighting points?
Which should i get thats suitable for cove lights
How about bathroom vanity top lights? what kind of power adapater/source is better/more suitable?
for cove light, use LED driver that connects to lighting point is a better option so that you can control the on-off of the light via a switch. Ask for the power consumption of the strip from the seller. choose a transformer with at least 10% reserve capacity.
for bathroom, find a waterproof LED driver rated IP67 or IP68. Ordinary driver might corrode under moisture ingression.
If you need LED drivers, you can PM me.
How about for those cabinets or feature wall lights should i change to those power supply or adapter will do?
so for bathroom i will require waterproof power supply as well as the light strips?
Hmz can pm me your contact for list of items you sell?
Do you have suitable led ceiling lights?
Hi Collins, why dont you provide your contact on your signature so that anyone interested in LED can contact you straight. if not, can you PM me your contacts? Thanks
