Aircon Installation
Hi guys, need some advice from any aircon gurus out there.
My aircon is installed in the room but the clearance from the unit and the ceiling is only about an inch. Is it going to cause any problem? or should i create a pelmut in the false ceiling for more clearance?
You will face problem when the fancoil need to do servicing or repair. To create a pelmet will resolve the issue.
aron (aronputt@gmail.com)
Thanks man. Told the guys to create le. Aircon man also told me the clearance needs to be there for air to flow me so that more air can flow out. ie allow cold air from compressor to flow out smoothly so as not to create condensation along the pipes.
