My Reno Quotes,Is It Too X? Pls Advice/Rate
Wets works / L box / False ceiling / Partition wall
Supply & construct { W300 x H150 } L box **** & dining room { 62 ft run }. $435.00
Supply & construct 2 rolls { W600 x H150 } L box at master bedroom { 31 ft run }. $280.00
Supply & construct false ceiling at main foyer,room passage & M/bedroom { 125 sq ft }. $385.00
Supply & construct false partition wall with gypsum board **** room $425.00
{ L1500 x H2550 x T75 }.
Supply & construct false partition wall with gypsum board at master bedroom $210.00
{ L750 x H2550 x T75 }.
Windows / Grilles / PD door works
Supply & install 4' 5 hts 3 way track sliding windows with green glass & podwer coating $840.00
frame at sre-yard { L2800 x H1350 }.
Supply & install 4' 5 hts of normal design sliding grilles with podwer coating frame at $380.00
Ser-yard { L2800 x H1350 }.
Supply & install 4 ft hts of normal design sliding grilles with powder coating frame at $1,140.00
living room,3 bedrooms & kitchen { 129 sq ft }.
Supply & install 3 nos of seleted swing & slide PD door at kitchen & 2 toilets entrance. $900.00
$3,260.00
Plumbing / Painting / Electrical works
Whole unit painting wall & ceiling + paint door frame only with 2 coating & 1 to 5 colour $1,250.00
choose { ICI or NIPPON Emulsion paint }.
All Carpentry works { Without Silent drawer system & Soft-closing door }.
Supply & install kitchen top cabinet with laminated finish & door a.b.s.trimming at sink $300.00
top { L900 x D300 = 3 ft run / per ft run $ 100 / all use solid plywood }.
Supply & install kitchen bottom cabinet with laminated finish & door a.b.s.trimming at $1,050.00
sink & cooker hobs area { L3200 x D600 = 10' 5 ft run }.
Supply & install kitchen cabinet top & bottom inclusive fridge top with laminated finish $1,800.00
& door a.b.s.trimming { 18 ft run }.
Supply & install solid surface worktop brand L.G. acrylic finish at sink & cooker hobs $1,155.00
area { 10'5 ft run / Base on $110 per ft run }.
Supply & install full hts casement door wardrobe with laminated finish & door a.b.s. $945.00
trimming at master bedroom { L1300 x H2400 x D600 }.
Supply & installfull hts shoes cabinet with laminated finish & door a.b.s.trimming at $770.00
main foyer area { L1050 x H2400 x D300 }.
Supply & install mount wall altar table with laminated finish & door a.b.s.trimming at $200.00
living room { L600 x W500 x H200 }.
Supply & install 1 panel of feature wall with laminated finish at T.V.console area $440.00
{ L1200 x H1200 x T50 to 75mm }.
Supply & install suspended T.V.console with laminated finish & door a.b.s.trimming at $525.00
living room { L1500 x W300 x H250 }.
Supply & install L shape full hts casement door wardrobe with laminated finish & door $1,680.00
a.b.s.trimming at master bedroom { L1800 & L600 x H2400 x D600 }.
Supply & install 6 ft hts cabinet with laminated finish & door a.b.s.trimming at master $400.00
toilet { W500 x H1800 x D300 to 350 }.
Tempered Shower Screen works
Supply & install 1 pcs slide & 1 pcs fix panel 10mm clear tempered glass shower $605.00
screen without S/S bar at master toilet { L1750 x H2000 }.
Supply & install 1 pcs swing & 2 pcs fix panel 10mm clear tempered glass shower $730.00
screen with S/S bar at common toilet { L1500 x H2000 }.
Floorplan
Edited by garywu
bro, show us your floorplan and the size of your unit.. that's better right?
why not you take the prices for carpentry and calculate on a per foot run basis? Then things become clearer. Initial inspection, some prices seem good, some abit pricier.
What are the pricer one??
NO electrical point quoted ???
alot og lihgt holder no lights point ??
total hw much ? can shs with me the ID / contractor for this?
