What Adhesive Glue To Use For Gypsum Board
Hi. Does anyone knows what is the proper glue to use for gypsum board? Thanks!
can check out those hardware store for adhesive glue(construction grade), come in silicon tubing type.
U mind sharing why u want to use adhesive glue?
Hi, cos i got some very big piece of left-over gypsum board and intend to paste onto my house-hold shelter door so that it flushes with the wall.
IMG-0876.JPG?et=Ekyrjv%2C1j1rNOIYOywDy4w&nmid=474284832
IMG-0877.JPG?et=ARkbXK2osDAoQz%2CmPBj6og&nmid=474284832
If you look at the pics above, the shelter door was about 10mm inwards to the wall. So i'm thinking if i can add one more layer of 10mm thickness to the door and flush it with the wall.
So that i can paint over and do some wall art using decals. =)
why don't u try drilling the gypsum board to the door instead?
in this case, it can still be removed in future with ease... :)
Good idea! But that door is a metal door and i'm not sure if HDB approve of us drilling it or not leh...
huh? metal door? whats the space behind the door for anyway?
Hi... its the household shelter... =)
then sealing it is not allowed dude. do at own risk...
Oh no, not that i want to seal up the room. I just want to put something on the door to make it flush with the wall.
And yes, i will have to use the room to store things too
Selleys Liquid Nail is a good adhesive for general building materials. It is certainly good for gypsum, but I'm not sure if it is good for metal especially smooth surface. But from the pictures given, I do not see how you can flush the gypsum board with the wall without sealing the entire door off.
Hi 70wood,
Thanks for recommending!!!!
Erm... i think should be able to flush without sealing the whole door. I'll just have to leave a gap between the door and the frame. =)
  • 3 weeks later...
bro it's unlawful to drill.... because it's SCDF shelter....
use maxbond.... looks like silicon...
just got any harware shop and ask for masbond can le
Hi ben263,
Ya, won't be drilling it.
I got buy Maxbond but the glue does not seem convincing leh... can really stick it ah?
