Cut To Size Glass Mirror
Appreciate advise on where I can buy cut to size glass mirror (~4x6 ft). Need it to replace current cracked piece on my wall... Thanks.
you should check the other threads...
it has already been posted before...
anyway you can go to kelantan lane...
you will not miss the glass frame maker..
Hi ben263,
I've actually search "glass mirror" under DIY section without success before posting.
Thanks for the Kelantan Lane recommendation. Will go there this weekend...
Better get a contractor to do it.
It's not a simple task to carry, transport and fix suchh a big piece of mirror.
You need something to suck onto the mirror when carrying or fixing up.
Mirror is most likely to be crack when place in laying down flat position.
Hi gladyslim,
Advise noted. Most likely will get a supplier that also provide transport and installation.
No contractor willing to do it at a reasonable price for me, some charging as much as $800...
Hi gladyslim,
Hi, yah true! My 127.5cm by 180cm tinted glass mirror cost about $800 also.
Maybe you can ask the shop people to deliver for you at a small amount?
To fix the mirror, remember to use Max Bond and let it settle for 3 days before removing. And use silicon on its sides for beauty.
Thanks paladin... :thumbs up:
  • 1 month later...
Yeap, kong Ying at kelantan lane......very friendly and cheap....
