adidasvintage
Ceiling Fan On False Ceiling Possible For 3Ng Resale?
It's fine as long as you don't raise your hand high while standing and swing your baby up in the air.... :sport-smiley-003:
But I think you need to talk to the contractor cause for my case, he had to build a support and modify the false celling ....it cost more then the fan itself.... :bangwall:
i remember 1 contractor told me no different cos the fan is still hang from the normal ceiling height ...
got it ?
it is not hang from the false celing height ...
hope i am correct ? ( menaing the contractor did not bluff me )
I wanted to do false ceiling and install a kdk baby fan in my master bedroom. Contractor agreed to it.
But when we studied dimension of the fan from its drawing, we feel uneasy to install the fan under false ceiling due to the height allowance. Also worry next time kids jump on the bed which is quite hazard.
My in law install ceiling fan on false ceiling, after 3 years we can clearly see a long crack line across the false ceiling. The ceiling fan is hardly on because it serve as guest room in weekends only.
Consider all these factors, at the end we gv up the idea of doing false ceiling. The fan will be mounted on ceiling directly.
If try the method of mount the fan directly on ceiling by going through an opening of false ceiling, you should check what is the height allowance between fan blade and ceiling. Best is to check the drawing.
Can do or cannot do I think is highly depends on the dimension of the fan and installation method.
I don't want to compromise on the model of fan I choose so I rather compromise to give up doing nice false ceiling.
