Parquet Re-Varnishing
Hi All...
would like to check if parquet re-varnishing work will be dusty? reason im asking is Designer mentioned this will be done only at last stage.. not too sure if after carpentry is up or not...
he is suggesting the below in stages.. i've only completed my tiling, all wet works and electrical wiring.. house is in mess and super dusty...
- false ceiling
- painting
- House Cleaning <== after this cleaning, will my floor be protected with corrugated paper again?
- continue electrical work eg light fixtures
- aircon installation
- carpentry work
- continue final touch up painting
- parquet re-varnishing (may i know what is the actual work process when they re-varnish)
Normally after carpentry work is done, does ID provide house cleaning again before handover?
appreciate fellow renotalks guidance...
thx
Edited by evo55555
Hi All...
- false ceiling
- painting
- carpentry work
thx
Dear Evo,
Just my two-cents worth of thoughts, regarding your questions.
- Carpentry before or after parquet flooring? It could be done either way.
If done before flooring/revarnishing, then make sure that the carpentry are protected with plastic sheet, to prevent possible tarnishing especially at the footing.
If done after revarnishing, then make sure that the new floor is protected to prevent accidental scratches by the carpenter during installation.
In my view, probably better to do the revarnishing before carpentry should there are lots to install.
- Cleaning?
I couldnt see the advantage of having the cleaning done so early as listed. The overall cleaning before handover is normally included in the quote (means it is not free).
Are you only revarnishing the parquet, with a re-grinding? If so, then the parquet is first sanded, vacuumed, and finally varnished. It sounds very straight-forward, but the devil is in the details.
1. All bathrooms (and areas with tiling done) should be protected or sealed, before sanding starts. Of course, also protect the carpentry as stated above.
2. Areas around the door frames, window frames (if there are), footings of carpentry should be properly sanded or treated (if done manually, not by machine).
3. The dust after sanding should be thoroughly removed by blower & vacuuming.
4. Varnish should be applied liberally and evenly. Let dry for at least 48 hours before stepping on.
Hope these help.
Cheers!
Edited by Lauer
