Quote For Reno:5 Rm Flat- For Advice
Hi, need some advice if this is reasonable...
A. Masonry works
1. To construct kitchen cabinet base, with side tiles, including fridge base in full tiles finish. -$395
B. Electrical works
1. Supply and run scv tv pont $150
2. Supply and run lighting points (16) - $720
3. Supply and run 13aMP double power point **** has (2) -$150
4. Provide labour to install ceiling/Plc light fitting (25) -$350
C. Plasterceil works
1. Supply and construct fibre plasterboard false ceiling at foyer -$220
2. Supply and construct fibre plasterboard false ceiling at bed room passage way -$150
3. Supply and construct fibre plasterboard at dining and living -$1520
D. Paint works
1. Provide labour and material to paint whole unit, including door frame, exposed pipes etc -$1350
E. plumbing works
1. Provide labour and material to extend cooper inlet piping for kitchen sink -$150
2. Connection and installation of kitchen sink/tap and inlet and outlet piping -$120
F. Glass/ mirror works
1. Install 2 tempered glass door (frosted) at main bath -$1100
2. Supply and install l6ft full height clear mirror at main bath -$396
3. Supply and install l3ft full height 10mm the fixed tempered class for shower area -$320
4. Supply and install l7ftxl4ft designated wall mounted bronze tinted feature wall -$1420
G.misc works
1. General cleaning upon completion of work $280
2. Provide labour and material to lay pine wood decking at balcony $1960
3. Supply and install l18ft solid surface work top at kitchen $1404
4. Supply and install class 1 granite for bay window $1820
5. Supply and lay wall paper **** $850
H. Carpentry works
1. To fabricate l6ft full ht laminated feature wall c/w tic tac system door at foyer $1330
2. To fabricate l10ftxh4ft l shape laminated swing door shoe cabinet with mirror door $2050
3. To fabricate l7ft wall mounded laminated tv console $1090
4. To fabricate l7ft full ht tv feature wall with l9ft pelmet $1850
5. To fabricate bottom l18ft,top l18ft laminated swing door kitchen cabinet with 2 sets drawers $4500
6. To fabricate l7.5ft wall mounded laminated study cabinet $1238
7. To fabricate l7.5ft wall mounded laminated study table $1213
8. To fabricate l8ft and l6ft full ht laminated sliding wardrobe $3920
9. To fabricate l6ft laminated vanity cabinet at bathroom $720
Total : approx $32,000
Appreciate your feedback and review :) thanks!
A. Masonry works
1. To construct kitchen cabinet base, with side tiles, including fridge base in full tiles finish. -$395 ($350)
B. Electrical works
1. Supply and run scv tv pont $150 ($100)
2. Supply and run lighting points (16) - $720 ($35 x 16 = $560)
3. Supply and run 13aMP double power point **** has (2) -$150 ($60 x 02 = $120)
4. Provide labour to install ceiling/Plc light fitting (25) -$350 ($250)
1. Supply and construct fibre plasterboard false ceiling at foyer -$220 ($160)
2. Supply and construct fibre plasterboard false ceiling at bed room passage way -$150 ($150)
3. Supply and construct fibre plasterboard at dining and living -$1520 ($1,380)
D. Paint works
1. Provide labour and material to paint whole unit, including door frame, exposed pipes etc -$1350 ($1,250)
E. plumbing works
1. Provide labour and material to extend cooper inlet piping for kitchen sink -$150 ($80)
2. Connection and installation of kitchen sink/tap and inlet and outlet piping -$120 ($70)
1. Install 2 tempered glass door (frosted) at main bath -$1100 ($480 x 02 = $960)
2. Supply and install l6ft full height clear mirror at main bath -$396 ($380)
3. Supply and install l3ft full height 10mm the fixed tempered class for shower area -$320 ($228)
4. Supply and install l7ftxl4ft designated wall mounted bronze tinted feature wall -$1420 ($1,200)
G.misc works
1. General cleaning upon completion of work $280 ($180)
2. Provide labour and material to lay pine wood decking at balcony $1960 ($1,960)
3. Supply and install l18ft solid surface work top at kitchen $1404 ($65 x 18 = $1,170)
4. Supply and install class 1 granite for bay window $1820 ($1,820)
5. Supply and lay wall paper **** $850 ($850)
H. Carpentry works
1. To fabricate l6ft full ht laminated feature wall c/w tic tac system door at foyer $1330 ($1,330)
2. To fabricate l10ftxh4ft l shape laminated swing door shoe cabinet with mirror door $2050 ($2,050)
3. To fabricate l7ft wall mounded laminated tv console $1090 ($1,090)
4. To fabricate l7ft full ht tv feature wall with l9ft pelmet $1850 ($1,850)
5. To fabricate bottom l18ft,top l18ft laminated swing door kitchen cabinet with 2 sets drawers $4500 (36ft x $110 = $3,960 including blum soft closing for all swing doors)
6. To fabricate l7.5ft wall mounded laminated study cabinet $1238 ($130 x 7.5 ft = $975)
7. To fabricate l7.5ft wall mounded laminated study table $1213 ($130 x 7.5 ft = $975)
8. To fabricate l8ft and l6ft full ht laminated sliding wardrobe $3920 ($260 x 14ft = $3,640)
9. To fabricate l6ft laminated vanity cabinet at bathroom $720 ($720)
Total : approx $32,000 Total : $29,808
Marked on RED can be lower
Hope the quote will help you
Hi blackwhite.sg
Thanks for reviewing.
I also feel that some of the items' pricing could be lower.
Will source and compare more quotes.
Thanks. :)
