Can This Faucet Fit To My Flat?
I bought a kitchen Faucet from USA which has two input, suppose to hot and cold water. but HDB only give one output. How do i connect it?
If u dun need hot water at the kitchen, then u connect the hot and cold to the incoming pipe using a T joint.
ya. i don't need hot water. I just disconnect and measured the existing one, connector is bigger in size. how many size do this connector have? is there a converter to this?
in Sg.. can get connector for all sizes.. but must bring to those sanitary pipe shop to try out... those shops that sell those copper pipe and fittings. Regular plumber can't be bothered to hunt such fittings for u.
any particular shop you referring?
i went to a few shop liao. find none that can fit into. mostly selling 1/2". any shop recommended
