Leaking Sink - Poor Workmanship Or Due To Cheap Sink?
Hello,
I keep having leaking kitchen sink problem. Kitchen sink is mounted underneath the solid top. Have tried to scrap off silicon; refill with silicon. The problem will come back after a few months.
Is this due to poor workmanship as in the contractor did not do the job properly or a cheap sink is being used? Expansion or contraction of the sink?
What should I do to resolve this painful repetitve issue? Change the sink? Possible to use existing back solid top?
Anyone has similiar issue?
Thanks.
Silicon is hopeless. Try something better. I recommend Shelleys Blockade. Is very sticky and much more durable. Cost $10.xx at Homefix.
some sinks have thinner sheetmetal, so warps easily.
But normally for undermount, if u got put generous solid surface overhang like 10mm, then seldom leak.
i would suggest to find the source of leak.
It could be the tap or the waster water trap.
