RiVeRGoD
Renovation Quote 5 Room Flat
Guys I am trying to find the prices for renovating as I want my new 5-room hdb renovated. I got quoted with the below prices. Is that expensive? I find it very. Please advice. Thanks in advance.
Item Description Qty Unit U/P Amount (S$)
Masonry Works
Living Area Tiles up to $3.00
1 Supply and Install Homogenous tiles for Living, dining and Hallway 538 sq ft 7 3,766.00
2 Supply and Install Tile skirting for Living, Dining and Hallway 100 ft 4 400.00
3 Bedrooms Short strips parque
3 Construct 50mm thk. Cement Screeding for 3 bedrooms 415 sq ft 4 1,660.00
4 Supply and Install wood parque for 3 bedrooms 415 sq ft 6 2,490.00
5 Supply and Install wood skirting for 3 bedrooms 105 ft 4 420.00
Total 8,736.00
Carpentry Works
Living Area
1 Construct full height TV Console in laminate finish **** area 8 ft 240 1,920.00
2 Construct full height Shoe cabinet in laminate finish in laminate finish at foyer area 7.5 ft 180 1,350.00
3 Construct sliding door in laminate finish in laminate finish at study rm. 7.5 ft 180 1,350.00
Dining area
4 Construct drywall partition in paint finish (double wall) 81 sq ft 8 648.00
5 Supply and Install full height Black mirror for dining area 81 sq ft 30 2,430.00
6 Construct full height display cabinet in laminate finish 8 ft 240 1,920.00
Kitchen area
7 Supply and Install Kitchen Top Cabinet in laminate finish w/ 1 set of disk rack 12 ft 120 1,440.00
8 Supply and Install Kitchen Bottom Cabinet in laminate finish 12 ft 120 1,440.00
9 Supply and Install Kitchen full height Cabinet in laminate finish 6.5 ft 240 1,560.00
10 Supply labour to Install Granite counter top 12 ft 160 1,920.00
11 Supply and Install 600x600mm Homogenous tiles for Backsplash 1 lot 400 400.00
12 Supply and Install Kitchen Sink Support in tile finish 3 ft 130 390.00
13 Construct 50mm kitchen cabinet base w/ tile skirting 1 lot 250 250.00
14 Supply and Install Inlet and outlet Pipe for kitchen sink 1 lot 180 180.00
Master's Bedroom
15 Construct full height wardrobe cabinet in laminate finish at Master's Bedroom 7 ft 240 1,680.00
16 Construct full height TV Console in laminate finish at Master's Bedroom 5 ft 240 1,200.00
17 Construct Study table with drawers in laminate finish at Master's Bedroom 3 ft 120 360.00
Master's toilet
18 Supply and Install Tempered Glass Shower Screen at Master's Toilet 1 lot 600 600.00
19 Construct Bottom cabinet in laminate finish 4 ft 120 480.00
20 Construct Top mirror cabinet in laminate finish 4 ft 120 480.00
Common Toilet
21 Supply and Install Tempered Glass Shower Screen at Common Toilet 1 lot 700 700.00
22 Construct Bottom cabinet in laminate finish 4 ft 120 480.00
23 Construct Top mirror cabinet in laminate finish 4 ft 120 480.00
Bedroom 2
24 Construct full height wardrobe cabinet in laminate finish at Bedroom 2 7 ft 240 1,680.00
25 Construct cabinet bench in laminate finish at Bedroom 2 6 ft 80 480.00
26 Construct study table in laminate finish at Bedroom 2 3 ft 120 360.00
27 Construct 2 Single bed with drawers in laminate finish 2 sets 900 1,800.00
28 Shifting of door opening 1 lot 350 350.00
29 Supply and Install doorframe for bedroom 2 1 lot 190 190.00
Bedroom 3
30 Construct full height wardrobe cabinet in laminate finish at Bedroom 3 7 ft 240 1,680.00
31 Construct Queen size bed with pull-out single bed in laminate finish 1 lot 2100 2,100.00
Study Room
32 Consrtuct study table with drawers in laminate finish 9 ft 120 1,080.00
33 Consrtuct top cabinet in laminate finish 9 ft 120 1,080.00
Total 34,458.00
Doors and Windows
1 Supply and Install 3-Panel Sliding glass window for service yard 40 sq ft 18 720.00
2 Supply and Install window grill for service yard 40 sq ft 9 360.00
3 Supply and Install window grill for living 65 sq ft 9 585.00
4 Supply and Install window grill for Master's Bedroom 45 sq ft 9 405.00
5 Supply and Install window grill for Bedroom 2 40 sq ft 9 360.00
6 Supply and Install window grill for Bedroom 3 40 sq ft 9 360.00
Total 2,790.00
Ceiling Works
1 Supply and Install L-Box **** Area 53 ft 9 477.00
2 Supply and Install False ceiling at Dining area and hallway 240 sq ft 3 720.00
3 Supply and Install L-Box at Master's Bedroom 40 ft 9 360.00
4 Supply and Install False ceiling for master's bedroom 1 lot 150 150.00
Total 1,707.00
Miscellanous Items
1 Wash whole house 1 lot 250 250.00
2 Painting Whole House 1 lot 1200 1,200.00
3 Sand Haulage Fee 1 lot 900 900.00
Total 2,350.00
GRAND TOTAL AMOUNT 50,041.00
Thanks mate. What should the carpentry work be? Please advice. Thanks.
this price is reasonable. but for your carpentry work, the pricing is only white pvc, not colour pvc
are u redoing your toilets? If so, there will be costs for tiling and installing of accessories? Is this a new BTO?
doors? Varnish main door will be about $80.
carpentry works is reasonable. Glass works, eg shower screen is expensive, but do not know the thickness and size.
actually your cost is inflated by unnecessary things, why do you need to construct beds? Arent single, super single, queen, king good enough, unless you want to extend the length of the beds? You can get beds from retail at half the price of customised carpentry beds.
Edited by paladin126
I think could be the ID giving the room a theme, so need to build the beds. but the carpentery price is reasonable.
Bro, i find your quote is ok. the renov cost is at 50K cause you are doing alot. cut dwn on your carpentry and you will save alot. good quote, pricing better then all the so-call ID'market rate. take a look at the workmanships 1st. CHEERZ, enjoy renov
Yeah... Too much carpentery only, price is not bad :thumbs up::dancingqueen::sport-smiley-004::thumbs up:
Edited by sandywu
Thanks its not BTO. But a recently completed SERS flat. Toilets likely overlay with new tiles as cannot hack within 3 years since its a new flat.
Thanks man. I'll probably remove the bed frames in there.
Arrrgh! Im totally confused now if I should engage ID or get contractors alone. What is everyone's take on this?
I want to know what should I look for in terms of type/brand/quality for the below list too, as thanks to this forum, I have been inducted to the terms like blum hinges, ABS trimmings, etc
1. Homogenous Tiles
2. Parquet
3. Hinges
4. Wood types
5. Granite types
Breaking down now. Reno experts, heeeeelp!!!!!
then how come there is no costing for tiling/masonry works for bathrooms?
what do you mean by white pvc not color? explain in details?
Hi crow,
white pvc here means the layer for the carpentry works interior. Internal white pvc is the basic layer used, even for ikea carpentry works. So cheaper.
Internal colored pvc means the internal layer of the carpentry work is colored = additional cost.
Hope this helps.
:yamseng: ,
Mike
Masonry Works
Total 8,736.00
Carpentry Works
Living Area
Dining area
Kitchen area
Master's Bedroom
Master's toilet
Common Toilet
Bedroom 2
Bedroom 3
Study Room
Total 34,458.00
Doors and Windows
Total 2,790.00
Ceiling Works
Total 1,707.00
Miscellanous Items
Total 2,350.00
HI.. CAN RECOMMEND ME YOUR ID? WHICH WEBSITE CAN I GO N TAKE A LOOK? THANKS..
Edited by crow
