crypaz
Home @ Punggol
Hey.. can check if the MBR has the L_shaped recess area also?
Mine initially dun have but i did the box up for down lights so now have...But it depends on your unit cause i seen a neighbour MBR with the L shape recess area.
Ok thanks.. your renovation works seems to be completing already... =P
Carpentry
Finally part of the carpentry is up...
Kitchen Cabinet
Shoe Cabinet
Hi Crypaz,
Will you share with me more images on your concrete sink area and its interior under the sink itself? Did your carpentry cover the area under the sink with wood too? I am trying to convince this idea in my discussion with ID, but need more fotos to visualise it...
Appreciate in advance.
Thanks :dancingqueen: :dancingqueen: :dancingqueen:
Your key collection date out ?
Yeap.. Next Friday! Finally after so long...
My theme also wooden.. Haha.. Selected most of my dining/living room furniture from Scanteak.
Lightings
Lightings are up!
Entrance Light
Living Room Track Lights
Hi crypaz,
can i check with u for ur track lights **** room and kitchen - how many watts and dispersion degree are the bulbs u use for the kitchen and living room track lights? we also want to have tracklights (in kitchen and bedroom) but are worried about whether lighting will be sufficient =P
TIA~!
sarah =D
Hi crypaz,
TIA~!
sarah =D
Hi...i dun know in detail but base on the invoice it's written as "CT800"...For my kitchen i find 3 track lights not bright enough intend to add another one...
As for my living room i'm using warm light meant for the wall decal...
If your areas is small (like my kitchen) then it's okay...but the lighting shop did advise for kitchen due to the cooking..when the track gets dirty will be difficult to clean...but if you doing mostly light cooking then it's okay.
Hi Crypaz,
Hi, my carpenter only over the outer area with wood, the area under the sink is still the tiles...
It's advised by my carpenter to have the sink support in case of leakage then your wood wouldn't get damage.
Will share more picture when i go down to see the progress of the reno.
thanks ahead. I just need something similar to your's sink area...
Exterior facade still remain with wood, while interior is tiles...
=D thanks for prompt reply! btw, is it LED lights or energy saving lights on the track? ya.. i was worried that the lights would get dirty too.. but i've read that the hood would help a lot in terms of oil extraction, and i dun think we'd doing too much deep frying (at most get a deep fryer?) so hopefully it'd be fine =D curiously, u're shining the lights on the cabinets?
Mine is LED lights...i didn't even install hood in the kitchen cause i dun know how to clean it so i decided to do away with it...i do mainly light cooking..steaming or just boil soup..or at times use oven to bake chicken...husband is health conscious...no fried food.
I plan to shine the lights on the table top instead...currently the area is not bright enough so i have to on the service yard light to help brighten the kitchen. Hopefully once i add another track light to the kitchen, it will be much better.
oooo.. maybe when u talk to them, u can try asking for a 8W and above LED bulb with a larger degree of light dispersion? normally when they intro the bulbs, they'll say 'this is a 8W light bulb 35 degree' or something similar.. the degree is an indication of how dispersed the light is.. the lower the degree (e.g. at 26 degree) the light functions more like a spotlight.. whereas at 35, it is more dispersed and might be better for the kitchen.. we also want LED tracks for the kitchen.. but in lieu of the light brightness, we're considering if we should switch to energy saving bulbs on track - but the housing is really quite huge!! rawrrr
woo…thanks for sharing… perhaps in terms of light dispersion, mine is of a lower degree? Cause inside my track light there's actually 3 round lights
When I bought the lights I only ask if it's bright enough. The sales staff showed to me and it was so bright that I can't look at it directly.
I treat the track lights as part of kitchen deco. If I'm not using track lights, I might go for pendant light instead for the kitchen.
