Quote For Renovation- Is This Expensive?
Hi all,
My ID just sent me a quote as per below. Can you advise me if this ok or which areas i should cut down? I am not the most experienced at renovation but i find the labour charges a bit much.
Dismantling works:
To supply labour to dismantle false ceiling: $200
To supply labour to dismantle wall feature in hall: $250
To supply labour to dismantle wall feature at masterbedroom: $100
Masonry Works:
To supply and overlay wall tiles at shower area only: $350
To supply labour to grind and re-varnish existing parquet floor for 3 bedrooms: $950
To supply and install new false ceiling: $650
To fabricate and install tv wall feature: $1400
To fabricate and install tv console: $1050
To supply and paint whole house: $1500
To clear debris for whole house: $450
To supply general cleaning and chemical wash: $300
To supply and lay cupboard sheet for whole house ( floor protection) : $250
To lay "Cheng Ai" wooden strip for balcony area (140sq ft): $2500
Payment terms:
1st payment: 15% upon confirmation
2nd payment: 40% (before commencement of work/delivery of materials)
3rd payment: 40% (upon completion of cement work/celing/ painting/ upon measurement or commencement of carpentry work at factory) ( includes full amount of Variation Order if any)
4th payment: 5% (upon satisfactory completion of all works stated in agreement)
Edited by Raul12
Hi all,
Dismantling works:
Masonry Works:
Payment terms:
you can change ID, I suggest
Why do you say that? Is this considered expensive?
Edited by Raul12
Quite reasonable bro, thats sort of market rate. sometimes too cheap leads to no good quality work as well
Hi all,
Dismantling works:
Masonry Works:
Payment terms:
Charges are high,
Able to cut down a little more
Hi all,
Dismantling works:
Masonry Works:
Payment terms:
Yours is a private housing? Private housing they charge slightly higher.
dismantling works price is ok. Parquet 950 is a little too high. market rates ranging from 500-600.
False ceiling cant comment as there is no measurement given. Same goes to the carpentry works. Clearing debris 450 is ridiculous. should range about 200 plus minus. and floor protection you can get it F.O.C if possible. wood flooring sounds ok. include varnishing as well?
Thanks bro. Yup, its a condo. What about the payment terms? Is it ok? I feel like i am not retaining enough cash at the end ( 5% not much considering that my reno is only about 15K)
Edited by Raul12
i suggest you go take up his project since both of you are so clicked :drunk:
