Repair Or Replace Part Of Kitchen Cabinet
i wanna change the sink cabinet into a concrete sink support. and i do not understand why i cant use my existing solid surface back. installing solid surface can cost around 1.4k plus the concrete sink support 1.6k thats a BOMB consider only this cabinet corroded.
you must think in the view of contractor, if they take out the countertop fix the contrete support and the the event that the solid surface break or scratch how? when risk and price is not equal they wont do.
maybr you can try change the wood below only which will be alot cheaper, must touch up the silicon to unsure no water goes down to thw wood cabinet.
Edited by jeffwei
  • 4 weeks later...
Thanks bro. i decided to DIY it. will upload the pic once the Project finish. hehe
  • 2 months later...
if you decide to diy it, a good option would be to get marine ply. though it is 2-3x more expensive, its a good investment
  • 2 months later...
For kitchen, moisture-resistant plywood would do, not too expensive also ;)
  • 7 months later...
Hi, I know this is an old post but is it possible to remove the wood under the sink & keep existing tabletop and build concrete support under the sink? Anyone did so can share here?
  • 1 month later...
To my understanding the existing table top can't be use back
Coz concrete support measurment unlike wood concrete support will be thicker then wood so existing tabletop will show reveal :jawdrop:
  • 1 year later...
So did your DIY already. Any pics and cost of your projects?
I having the same problem.
