I stand corrected, but in the future if for some reason you need to subscribe to two or more ISPs on fibre (e.g, SingTel & StarHub to deliver different services to different rooms), this might pose a problem unless you have two or more Cat 6 cables running from your utility room to the place you put your router. But I guess this is unlikely for the majority of users.
Actually this is the main reason why I insist on running my own fibre from the TP in the utility closet to the TV console area so that I can place my ONT there but it's more for the possibility of subscribing to internet and pay-TV with different providers. Like you said, this should be inapplicable to majority of users and more of a nice to have.
  • Replies 467
  • Views 247.3k
  • mavicaste
    mavicaste
    Hi kelhy, this is how the back of the TV and the inside of the console looks like. It is rather tidy at the moment as I have yet to get a Blu-ray home theatre system as well as an Intel NUC hooked up
  • Home Networking Being the geek, I insist on having this post for the other geeks out there as I understand the frustration when searching for technical information on these forums. Having consider
  • Hi! I'm one half of this home, thought I'd contribute with my side of this home planning. Here's a quick review of some of the furniture places we've visited. Personally I like one-off furniture a lo
Just ordered 2 of these patch panels each from Amazon along with the Platinum Tools EZ-RJ45 crimping tool and connectors. I decided to spend a little more on the proprietary crimping tool and connectors instead of the standard ones as I will be crimping plenty of cables and these are definitely easier on the noob.
TRENDnet TC-P12C6 12-Port Patch Panel - Using 2 of these instead of a single 24-port version to reduce the width of the shelf required to house them and also because my switch's ports come in a 12 ports by 2 rows configuration
TRENDnet TC-P08C6 8-Port Patch Panel - 1 unit for the study desk and another unit for the TV console instead of using multiple faceplate terminations
Edited by mavicaste
Wah, your stuff very Hi-tech leh. lol
Can get you become my shifu a not? :lol:
All this structured cabling and self termination is new to me as well, just decided I want to go down this route and "force" myself to pick up some knowledge.
i read somewhere in this forum uses cat 7 cables. have you considered that ? my contractor only provided cat 6. :dunno:
I had lay the structure cabling. Just another stupid questions har, from my room data pt, anyways to split it into 2 PC? :notti::notti:
think if you get a switch in your room will work. maybe a small 4-port switch will be sufficient
Cat7 is meant for 10 Gigabit networks and I really don't see it becoming mainstream for consumers within the next 4 to 5 years.
Having said that, Cat6 is still capable of supporting 10 Gigabit networks if properly laid and terminated but at shorter distances of course, though it is unlikely to exceed the recommended 37m in the worst case scenarios for HDB homes.
http://en.m.wikipedia.org/wiki/Category_6_cable
Edited by mavicaste
Yes, using a switch will be the most cost efficient and straightforward solution.
Thanks for both of you!
Never knew such switch exits till I google it just now. lol
thanks for that :good:
We had the air-con vendor come in yesterday to run the piping and I have to say their workmanship is really good as reviewed by the other forumers. They also cleared up the debris and waste after the installation was done.
The position of the units and routing of the trunkings were straightforward for most of the rooms except for the living room. Due to the design requirements of L-boxes above the sofa as well as the other side of the wall in the study, we could only place it on the beam above the passageway entrance. This should be a more or less standard practice for most BTO flats with similar passageway layouts. As the study wall is hacked right up to the beam, the only way is to route the trunking just above the household shelter and bathroom doors. If we choose to conceal this trunking in the passageway, the only feasible solution is to lower the study wall from the beam and to drop the false ceiling all the way down to the height of the doors. This will cause the passageway to appear narrower but we should be able to live with it.
Material and Tools
Living Room
Study
Bedroom 1
Edited by mavicaste
Hi mavicaste, care to share your ID and air-con vendor?
my email is cioe@live.com
Check your email.
For new forum members and readers who may wish to request for any contacts or additional information in the future, I would like to take the opportunity to point out that these forums have a private message function available. ;)
Edited by mavicaste
