Advise Needed For Renovation Quotation 4Room Bto
EXCLUSIVE PACKAGE FOR HDB STANDARD NEW FLAT*
(PROFESSIONAL SERVICES)
Space planning & conceptualizing
Furniture planning & products pre-consultation Project management, site supervision & auditing 3D drawings for all carpentry works
3 years warranty & guarantee after sales service
MASONRY WORKS)
Supply & lay 600MMx600MM polished Homogeneous floor tiles @ Living/Dining (Max. $3.00 psf)
Supply & lay 600MMx600MM polished Homogeneous floor tiles OR Laminate floor @ all Bedrooms
Supply & lay Homogeneous skirting OR Laminate skirting @ Living/Dining & all Bedrooms Construct 50MM height Kitchen Cement mortar base with tiles skirting
Construct 50MM height washing machine base & fridge base with full tiling
Construct Main entrance kerb
PLUMBING WORKS)
Supply & install inlet & outlet piping for Kitchen sink
Supply & install inlet & outlet piping for washing machine
Supply labour to install Kitchen sink & tap
Supply labour to install 2 sets instant heater OR storage heater Supply labour to install 2 sets Bathroom accessories
CEILING WORKS)
Design & construct L-BOX @ Living/Dining
Design & construct false ceiling @ Foyer area
(CARPENTRY WORKS)
Design & fabricate 20ft(Top & Bottom)Kitchen cabinet using solid plywood with Laminate + BLUM soft closing hinges
Supply & install 10ft solid surface worktop
Supply & install designer handles
Supply & install 1 set frosted glass door
Supply & install 1 column of drawer with 1 set cutlery tray
Design & fabricate 5ftL built-in wardrobe @ Master Bedroom in Laminate
(MISC. WORKS)
Painting of internal wall & ceiling using NIPPON paint (Max 4 Colors) Painting of all doors,frames,pipes & gate
Provide corrugated paper protection to flooring
Chemical washing for whole unit
General cleaning upon completion of works
SUB TOTAL AMOUNT FOR PACKAGE : $ 10,288.00
A
1
2
(ADDITIONAL WORKS)
(HACKING & DEMOLITION WORKS)
(BEDROOM 3)
Supply labour to demolish away one of of hollow block wall between Bedroom & Master Bedroom $600 (Subject to HDB approval)(Excluding PE endorsement if required)
Supply labour to dismantle & hack away ext'g metal door frame $120
MASONRY WORKS)
(BEDROOM 3)
Supply labour & materials to render smooth to affected wall & ceiling areas $350
Supply labour & materials to seal up ext'g door opening using 63M thk hollow blocks $350
Supply labour & materials to cement plaster smooth to both sides of wall $200
(KITCHEN)
Supply labour & materials to construct additional 50MM height Kitchen cabinet base $300
(MASTER & COMMON BATHROOM)
Supply labour & materials to construct shower kerb c/w full tiling $300
(CEILING WORKS)
(LIVING AREA)
Supply labour & materials to construct Cove light holder $400
(DINING AREA))
Supply labour & materials to construct plaster false ceiling $550
(PASSAGEWAY)
Supply labour & materials to construct plaster false ceiling $250
(ELECTRICAL WORKS)
(LIVING AREA)
Supply labour & materials to run 6 nos PLC downlight points $306
Supply labour & materials to run 6 nos Cove light points $306
Supply labour & materials to relocate 1 no SCV point & 1 no 13AMP Double point to TV wall $230
(DINING AREA))
Supply labour & materials to run 04 nos PLC downlight points $204
(PASSAGEWAY)
Supply labour & materials to run 2 nos PLC downlight points $102
(KITCHEN)
Supply labour & materials to install 1 no cooker hood point $70
(MASTER BEDROOM)
Supply labour & materials to relocate 1 no SCV point & 1 no 13AMP Double point $150
(OTHERS)
Supply labour to install 9 nos Lighting $165
E (CARPENTRY WORKS) (LIVING AREA)
1 Design & fabricate 6ftL x F/H design TV feature wall using solid plywood in selected high grade Laminate finished $1380
2 Design & fabricate 6ftL x L/H wall mount suspended design TV console using solid plywood in selected high grade Laminate finished $990
(FOYER AREA)
1 Design & fabricate 4ftL F/H design shoe cabinet using solid plywood in selected high grade Laminate finished $1160
2 Supply labour & materials to alter to DB cabinet door $180
(To receive flase ceiling height)
(KITCHEN)
1 Design & fabricate additional 2ftL Kitchen cabinet in Laminate finished $240
(Package consists 20ftL)
2 Supply labour & materials to install additional 1ftL solid surface worktop $85
(Package consists 10ftL)
3 Design & fabricate 4ftL Bottom Kitchen cabinet using solid plywood in selected high grade Laminate finished (Dry Kitchen Area) $480
4 Supply labour & materials to install 4ftL solid surface worktop c/w complete backsplash $340
(Dry Kitchen Area)
5 Design & fabricate 2ftL x F/H Tall unit cabinet using solid plywood in selected high grade Laminate finished for Built-in Oven & Microwave $720
6 Supply labour & materials to install additional BLUM system soft closing hinges $280
(BEDROOM 3)(SON'S ROOM)
1 Design & fabricate 6ftL x F/H Casement doors built-in wardrobe using solid plywood in selected high grade Laminate finished $1410
(BEDROOM 2)
1 Design & fabricate additional 5ftL x F/H Casement door wardrobe $1175
(Package consists 5ftL)
2 To convert 10ftL Casement wardrobe to Walk-In wardrobe c/w internal color polygrene $800
(w/o doors)
3 Design & fabricate 9ftL x L/H wall mount suspended Study Console using solid plywood in selected high grade Laminate finished $1620
4 Design & fabricate solid plywood Laminate sliding doors @ entrance between Bedroom 2 & Master Bedroom $1200
F (WINDOW WORKS)
1 Supply labour & materials to install aluminium sliding window @ Service Balcony $680
(BA/NA)
G (GLASS WORKS) (MASTER BATHROOM)
1 Supply labour & materials to install 10MM thk clear Tempered glass swing door shower screen @ Master Bathroom $650
H (DOOR WORKS) (MASTER & BEDROOM 3)
1 Supply labour & materials ot install 2 nos design Veneer door c/w complete lockset & door stooper
(MASTER & COMMON BATHROOM) $660
1 Supply labour & materials to install 2 nos alum frame acrylic bi-folding doors $520
(COMPLIMENTARY ITEMS) GRAND TOTAL AMOUNT Grand total: $29,811
A 1 NO STAINLESS STEEL KITCHEN SINK
B 1 NO DESIGNER KITCHEN SINK TAP
Yes, pricing is reasonable. as for quality output, we wouldn't know (unless you visit a near completion flat unit by the ID).
Do take a look at the comments below. Hope it help you out.
From the quote below till before additional works seems like it is a package. correct me if i am wrong.
MASONRY WORKS)
Why there is no 50MM height kitchen base within the package? this is a common thing and should be in the package.
PLUMBING WORKS)
Please ensure it you are installing storage heater ensure that the piping runs hot and cold. if not last minute they will charge you extra for it.
CEILING WORKS)
(CARPENTRY WORKS)
this is just a safety concern. try not to have handles for the kitchen cabinet. you will not know when will get hook on the handle and cause mishaps. just mine personal comment. no offences.
(MISC. WORKS)
what type of nippon paint you are able to use? due to there are many different types of it.
A
1
2
(ADDITIONAL WORKS)
(BEDROOM 3)
MASONRY WORKS)
(BEDROOM 3)
(KITCHEN)
as mention above. should be within the package.
(CEILING WORKS)
(LIVING AREA)
(DINING AREA))
(PASSAGEWAY)
(ELECTRICAL WORKS)
(LIVING AREA)
(DINING AREA))
(PASSAGEWAY)
(KITCHEN)
(MASTER BEDROOM)
(OTHERS)
ok as for the lightings if you are keen on L.E.D light to pm me. as it safe electricity bills in the long run.
as they had mention high grade laminate finished, well check with them is the interior of the drawers are the same color as the laminated color you have choose? this goes to all the wardrobes in your room. kitchen wise most likely they will put interior drawers white. but do check no harm.
(FOYER AREA)
(KITCHEN)
(Dry Kitchen Area)
(BEDROOM 2)
(w/o doors)
F (WINDOW WORKS)
(BA/NA)
actually some things you can buy off the shelves. will save cost a lot. hope that helps.
Hi 5piderman, your Quotation looks reasonable, kindly PM ID contact. TIA.
  • 1 month later...
  • 1 year later...
