Hi Need Help For Wire
I assume you are trying to build your own extension cable; i.e. to connect a cable from the socket to the plug?
If so, you need a 3 core wire,
- connect ground wire from plug ground to socket ground
- connect neutral wire from plug neutral to socket neutral
- connect live wire from plug live to socket live
- Done
You need a back box for the socket.
http://www.macbuildingproducts.com/product_info.php?cPath=25_749_495&products_id=20346
Hmm what color to what color
Like ground what color
Neutral what color
Live what color
if you aren't familiar with electrical stuff I won't recommend you to.
Anyway, the colours are like here
Brown - Live (the most dangerous wire here)
Blue - Neutral
Yellow/Green - Earth
If you look at the wall socket (the "hole" where you push the plug into the wall)
Top is earth, left is neutral, right is live.
Tools needed, screwdriver, wire cutter (scissors will do if you have a strong one)
Edited by LIftyTech
You will also need
1) an electrical hammer drill to drill holes on the wall for securing the back box.
2) Screws and wall plugs to fasten the box to the wall.
3) Cable trays to run you new wires in.
4) Nail & hammer to secure the cable tray to the wall.
5) Or buy cable tray with double side tape then can skip (4) above
Considering the above, maybe an off-the-shelve extension socket works just fine.
Just joking but these are the items I'll need.
Next question follows:
Any volunteer to help?
provided if thread starter still remembers he needs it to be done and asked for help here. :notti:
  • 5 months later...
Blue - Neutral
Ya that is is correct
