July 26, 201412 yr Hi All,Wanna check with you guys. For units that are situated near a school and beside MRT tracks. There'll be the noise from the school morning ceremony, etc... noise from the MRT travelling past your home etc..Is there a way to eliminate or at least minimise the noise level? Does double glazed glass windows do wonders?
July 26, 201412 yr Complain lah-: ask others to make changeshttp://app2.nea.gov.sg/anti-pollution-radiation-protection/noise-pollution-controlOrClose window, turn on air-con.Or, save electricity and the earth by putting on ear plugs.Noise comes from everywhere, not only through windows/air. Good luck.
July 26, 201412 yr Author first, does HDB approve this double glazed glass windows?Hmm, I did come across a T-blog thread whereby the owner installed double glazed windows. Not sure about approval though.Am looking for resale units, so came across this unit.. was thinking if there's solutions to the noise.. but think will probably pass. These windows aren't cheap, plus next time wanna resell might not be easy again. =)
July 27, 201412 yr Double glazed glass designed meant for heat & acoustic sound isolation.It work well as 'fixed' glass panel - imagine a wall vs a fixed double glazed window.Casement or sliding windows have this gap 'leakage' issue- not '100% air-tight'....so....'Triple' glazed also won't help much as 'window' - 'fixed panel' is another issue.
July 27, 201412 yr Author Double glazed glass designed meant for heat & acoustic sound isolation.It work well as 'fixed' glass panel - imagine a wall vs a fixed double glazed window.Casement or sliding windows have this gap 'leakage' issue- not '100% air-tight'....so....'Triple' glazed also won't help much as 'window' - 'fixed panel' is another issue.Noted. Thanks man...
