Advise On My New 5 Room Bto Quote
I just got my keys to the new BTO was quoted by an ID for the following and was thinking if some of the items on the quotation are too expensive or not. Any bros/sis able to advise ?
Lay selected Vinyl floor finish for Living and Dining Area
Construct 50mm Plinth for Kitchen Cabinet base
Lay tiles for existing common toilet entrance kerb
Lay tiles for existing master toilet entrance kerb
Construct Shower kerb for Master & Common Bathroom
Lay selected vinyl floor finish for 03 bedrooms
Connect PVC drainage piping for Sink & Washing Machine inclusive
Install 01 no of Kitchen Sink inclusive
Install 02 sets of accessories for 02 Bathroom inclusive
Installation of bidet spray inclusive
False ceiling @ Entrance Foyer proposed on plan
False ceiling with Light cove design @ Living Area proposed on plan
False ceiling with Light cove design @ Dining Area proposed on plan
Curtain pelmet 6" inch drop @ Living Area proposed on plan
20ft selected Laminated Kitchen Cabinet inclusive of the following inclusive
Blum soft closing hinges inclusive
Blum Aventos HK 01 set inclusive
03 sets of Blum Antaro/ Intivo series drawer set inclusive
10ft Solid Surface Worktop (Selected Design) inclusive
01 set selected Stainless Steel Dish Rack inclusive
Installation of Owner's Hood & Hob inclusive
Install 01sets of 10mm Tempered Glass panel c/w swing glass door for Master Bathroom
Supply & install x01 set of swing/slide system door consist of aluminium frame c/w 2 full acrylic door panels at Common Bathroom $400
Supply & install x01 set of swing/slide system door consist of aluminium frame c/w 2 full acrylic door panels at Master Bathroom $400
Paint all walls & Ceiling
*up to 5 color selection for wall
Lay Protection Paper for whole house
Chemical washing of whole unit upon handover of unit
General Cleaning for whole unit upon handover of unit
Supply & install 35mm thick L900mm x H2100mm raw finish hollow core veneer room door c/w yale lever handle for 03 new bedroom doors $1350
fabricate 2x additional L1200mm x D600mm bottom kitchen cabinet c/w swing door $1200
* inclusive ABS side trimming for door panels
  • color pvc proposed for all internal carcass
  • inclusive "BLUM" anti-slam hinges for door panels
Additional L1200mm x D600mm (I series) Iquartz single profile c/w H50mm backsplash
Fabricate & install L2100mm x full ht tv feature panel using mdf board with front selected laminate finish $2200
Fabricate & install L2100mm x low tv console in selected laminate finish c/w front pane based on proposal layout plan $1100
*(Internal Carcass : Selected grey color pvc)
*(Blum soft closer hinges for door panel)
*(ABS trimming door panel)
Fabricate & install L1800mm x L2700mm 3"to 4" high plywood platform raise up at suggested study area $1000
Fabricate L2100mm x D600mm x H2400mm 2 door panel uv sliding track wardrobe in $ 2100
* inclusive ABS side trimming for door panels * color pvc proposed for all internal carcass
Total: $27432
Edited by tangle
They need to give you a more detail breakdown of the specific line item. I was quoted 700+ for hk Aventos for Blum you can use that as one point of reference.
Hi tangle. The price is a little bit high tho.
Thats what i thought to. Lucky i'm not the only one :good:
Noted. Thanks for sharing!
