jimmya
Is This Quote Cheap And Reasonable?
Do advice.
Construct fridge base - $150
c/w Blum Hinges
c/w Color polygon
- all doors in ABS Trimming
- 1 set of cultery tray
Chemical Washing - $200
Total $22235.
Do advice and help me out.
thanks
can PM me @fun2av66@gmail.com for this id? thanks in advance
Hi jimmy, very nice, n also quite close to 3d drawings except for dining table haha. Thanks for sharing. I'm starting soon wish me luck. Hopefully he can do the same job as he did for u. :)
Guest Vicki Goh
Congrat Jimmya..you got a very nice and cosy house. Your bedroom color very nice and cool...
So you have already move in right? Btw you did not do any curtain?
Edited by Vicki Goh
Hi Jimmy, congrats on your new house! It looks really good from the drawings and all.
Can you PM me the contact of your ID/contractor? Looking for one for my new BTO too. Thanks in advance!
