Is This Quote Cheap And Reasonable?
On ‎26‎/‎07‎/‎2015 at 2:05 PM, jimmya said:
Hi all,
I received this from my ID, is it reasonable? So far this is the lowest that i had got from 5 IDs.
Do advice.
Thanks
Construct 50mm kitchen base 11.5ft - $420
Construct fridge base - $150
Construct washing machine base - $150
Supply cement, material n labour to lay 600x600 Homogeneous tiles for living room - $3360
Supply cement, material n labour to lay 600x600 Homogeneous tiles for master bedroom room - $1800
Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 2 - $1180
Supply cement, material n labour to lay 600x600 Homogeneous tiles for bedroom 3 - $1100
Supply labour to install 1 gallon heater - $120
Supply labour to install kitchen sink & tap on existing point - $100
Supply labour & material to lay 2” conceal drainage PVC for kitchen sink and washing - F.O.C.
Design, Fabricate & Install est(11.5ft) Kitchen top cabinet in solid-ply finish with high grade EDL/LAMITAK laminate - $1495
c/w Blum Hinges
c/w Color polygon
- all doors in ABS Trimming
- 1 set of hydraulic hinge gas spring
- 1 set of sand blast glass panel
- 1 set of cultery tray
- 1 nos.of 2 tier dish drainer
- labour to install cooker hood & hob - F.O.C
Design, Fabricate & Install 8ft tv console - $1040
Design, Fabricate & Install 8ft Feature wall - $1600
Design, Fabricate & Install Full Height Shoe Cabinet - $850
Design, Fabricate & Install Full Height Sliding Wardrobe est 6ft - $1560
Supply Labor & Materials to construct LBOX **** area - $1120
Custom made & install 11.5ft Quartz - $1265
Fabricate & install Glass Casement door at kitchen Entrance - $550
Fabricate & Install Shower Screen casement door at master bathroom - $500
Fabricate & Install Shower Screen sliding door at common bathroom - $550
Painting of whole unit using Nippon Original Paint using 5 nos. Colors - $1250
- all internal wall with Nippon Vinilex 5000 paint
- ceiling using Nippon Maxtex white color paint
Corrugate Paper for Protecting Existing Flooring - $180
Whole house general cleaning - $200
Chemical Washing - $200
Total $22235.
Do advice and help me out.
thanks
Hi Jimmya,
please pm me your id contact.
TIA. :)
  • Replies 723
  • Views 260.7k
  • Pretty good pricing from this particular id. However, just a note that if this quotation appears to be much lower than the other four ids, do a "safety" check like googling this id, searching on reno
  • tarzanboy
    tarzanboy
    Hi, jimmya the price look great can pm me the id contact and company details as currently looking for one thank.
  • Hi , Pm u already little pig, sea hew , purple earth. Take care All d best !
Posted Images
Hi Jimmya,
may I have your ID's contact please? Thanks
I had recently encountered a case where the renovation contractor causes a water pipe to burst and there is water dripping all over. So, advice all not to take it lightly and trust lousy company. I highly recommend Sigmon construction.
Hi Jimmya,
Thank you very much!
Hi, can pm me the contractor details? Thanks!
hi guys, had pm u. my photos are in thread page 10.just in case u want to see
coz alot of u had ask me about my house reno.
all d best!
On 8/15/2016 at 9:06 AM, dabendan said:
Hi guys, is this quote reasonable ?
eh? thought you posted that you did 9k renovations from a renovation company le?
Hi Jimmy,
Could you pm the contacts of the ID and his company? Thanks
bro,
do pm me the contact details.
went for quite a few ids, the price is very wide range,.. at least urs is reasonable price.
thanks alot.
hi, can share the ID contact to me? thanks.
  • 3 weeks later...
HI , can you pm me the details of the ID?
Thank you.
0
