Need Advice Before Signing Reno Package Deal
Hi all!! Newbie need help again😁
I came across in the net regarding customer need to pay more after sealing the deal due to some lacking of items/services
Any advice care to share to avoid this mishap?
Thinks to take note and lookout for? Any misc?
Really scared if the reno suddenly will burst our pocket..
Thank you in advance for all ur feedback😄
hi dba,
most of the time will add abit. bcoz only at the actual side then the contractor will tell u there's an area or something
that needs to cover up, u can only see at ur actual house. but its all up to u. on floor plan cannot see the edges..
i also pay a little more to cover my edges...a few hundred only la. haha.
Hello again!
To avoid big shocks... Avoid signing packages. For eg if you saw jimmya's quotation he probably would not get a shock. It's easier to discuss what to include and exclude.
During the quotation meetup with id always ask if there's anything missing. A good id would suggest to you additional items you can consider. It's still best to trash out everything before signing the deal!
After signing, some additions would be the electrical works, and likely some unforeseen measurements, which can instead decrease cost if some areas did not use as much materials as expected. For this, do check with id what are some these additionals and they should gladly tell you the cost breakdown.
Noted..thank you for the feedback😊👍
