Replace Laminated Flooring With Vinyl Flooring
Anyone done this before? The existing laminated flooring need to be removed before install new vinyl flooring? What will be the estimated cost for removal?
Why not just lay over existing floor? Laminate thickness is 8mm - 12mm but vinyl is 4mm - 5mm, so unless you are changing the doors there will be the unsightly gap if you removed the laminate floor.
