Uchi
Is my jamban a weird size?
Hi everyone, I just removed my W.C. because it was leaking, and now I'm looking for a new one. I need an S-trap type. However, most of the ones out there seem to specify 150mm distance from the back wall for the waste exit.
I've measured my hole (not mine specifically, but the one for the W.C.) and the centre of it seems to be 130mm from the back wall. I've attached a pic.
Does anyone know if my hole is weird? Would a 150mm toilet fit?
Edited by Uchi
22 hours ago, LuckyKhoon said:
This is quite normal, just get a 6" S trap WC with a 1 inch offset pan collar.
Thanks for that :) Very helpful indeed.
I haven't dared look at the bottom of my old toilet bowl... I guess there'll be one there that I can re-use?
Edited by Uchi
Dear Uchi
Since you are changing your WC, just have the supplier supply the suitable pan collar as well.
Some things are not suitable to be re-used, and this is one of them.
  • Like 1
Dear Uchi
Thanks, mate! ;)
