Strictly Scandinavian (3 Room 65Sqm BTO)
14 hours ago, Pooroldman said:
Hi flowersinherhair ,
Sorry for the second question , they lay the tiles straight to the raw flooring ?
Thanks
Hi flowersinherhair,
As for the AC , the switch is provide by the installer or connect to switch that HDB install ?
Thanks
@Pooroldman I have not decide the switches, any advice whether it is better to use switch installed by installer or connect to switch that HDB installed? :)
As for your second question, do you mean the cement screeding?
7 hours ago, Clarence Lye said:
if you see closely, there's cement below in the circle area. that tool at the top is the tool they use for "scrapping" the lines on the cement before laying the tiles
Something like this one:
@Clarence Lye  Thanks for your clarification! Is this cement screeding?
1 hour ago, Songz said:
The tiles look woody, I nearly thought it was Vinyl before reading :good:
@Songz Yea I like woody tiles.. How come it looks like vinyl haha?
Actual photos taken at the shop, this is the colour of the tiles under natural sunlight. :)
Edited by flowersinherhair
  • Replies 87
  • Views 69.3k
  • flowersinherhair
    flowersinherhair
    Mood Board The theme chosen is Scandinavian, mostly white with calm, muted tone of grey and pastel colours.  LIVING ROOM     KITCHEN
  • flowersinherhair
    flowersinherhair
    @Diluted  Yea I supposed so,  it's quite a common brand and it's from Taiwan. The motor warranty is 10 years, while other parts of the fan come with one year warranty. KDK is only one year warranty II
Posted Images
Not the cement screeding but the cement layer underneath the tiles.
@Clarence Lye Ohh, I'm not sure about this, will check with my contractor..
Day 16
More updates, photos were taken during daytime. Flooring is more or less done, only left the skirting. Tilers will proceed to do my feature wall tiles next.
Day 18
Feature wall
Went down to take a look, flooring is completed. Is it just me? I find that the feature wall grouting is a bit too big (8mm), and the colour of the plaster (?) used doesn't match with my bricks? Should I ask the workers to redo? Please kindly advise!  :(
8mm grouting.. See the colour of the plaster (?), colour looks a bit off? Should I ask the contractor to change it to a lighter colour?
Is this acceptable? Or am I being too OCD/picky?
Living room floor tiles
Overall quite happy with the tiles I have chosen, even though it's made in China.
Common bedroom floor tiles
Master bedroom floor tiles
Kitchen cabinet base
Service yard base
Will be boxing up the pipes. Washing machine will be placed on this side.
Will be installing a sink on the other side of the service yard, contractor runs a pipe from the other end, the water piping will be hidden inside the boxed up thing that you see on the left hand side.
Day 27
Hi everyone, it's been 2 weeks since the renovation have started, tiling works are almost done, minus the half of the feature wall on the tv side, cos the electricians are doing electrical works on that part of that wall. Skirting is also not done yet. I shifted quite a bit of the electrical points, and added a couple more.
These are my finalised electrical points:
Living room: Total 7 points
- 4  (added 2) on the TV console side.
- 2 on the sofa side, added another one by the window.
- Shifted telephone point to TV console side
Common bedroom: Total 5 points
- 3 (added 1) by the study table, 2 by the bed.
Master bedroom: Total 7 points
- 3 (added 1) by the lounge chair
- 2 by the study desk
- 2 (added in) by the TV cabinet
Kitchen: Total 6 points
- 4 on one side, 2 on the other side
Service yard: Total 3 points
- 2 (added 1) on washing side, added another point on the other side of the service yard for my garment steamer.
Bomb shelter: Total 2 points
Total number of electrical points: 30 points.
Is it too many? :wacko:
Some photos to share..
Removed all the window panes from the service yard windows..
This is the entrance of the master bedroom, aircon is supposed to be placed at the entrance and there is a trunking on the left. See how the trunking has been boxed up nicely! :P
This is the master bedroom's bathroom, my contractor suggested removing the honeycomb panel so that I can accommodate a taller rain shower, so pleased with my contractor for advising me to do this! My original plan was to remove the honeycomb panels and replace them with acrylic panel, installing T5 lightings inside. My contractor suggested doing it in another way: remove all the panel boards, box up that portion instead, now my toilet ceiling looks higher and more spacious!
Likewise for common toilet, my contractor removed all the panel boards, will be boxing up the pipings.
This is my walkway leading to the bedrooms. My initial plans was to placed 2 simple downlight along the walkway. As there are air con trunking running down the walkway, my contractor suggested boxing up the trunking and add downlights in the trunking instead. Good idea!
On 03/10/2017 at 11:59 PM, flowersinherhair said:
Day 14
Wet works proceeded after air con installation. Met up with my contractor over the weekend for a discussion.
Tiling works begin today. We got our living room and bedroom floor tiles from Lian Seng Hin
http://www.liansenghin.com.sg/index.php?route=product/product&product_id=88
Each tile is offset by 200mm, arranged in a staircase fashion.
As for the feature walls,  I got them from Hup Kiong.
http://www.fioranese.it/en/floor-and-wall-tiles/urban_avenue/
Off white version, will be arranging them horizontally in a random manner, with a 8mm grouting throughout.
Half the living room has been completed, if everything goes well, tiling works will be completed by this weekend. Will be back for more updates then, stay tune! :)
Hi
Hw much u pay for the floor tiles (Lian Seng Hin) per sqft?
Thks
7 minutes ago, Pooroldman said:
Hi
Thks
@Pooroldman Hi, if I didn't remember wrongly, the tiles cost $6 per piece. They are made in China though.
Ok ,Thanks .
Day 39
Hi everyone, it has been more than a month since my renovations have started. Just confirmed all the carpentry works so hopefully everything will be ready in one months' time as the good date for me to move house is advised to be end of November, if I miss this date, I have to wait til January next year, and I have to vacate from my current place by Dec! :(
Progress has been rather slow recently cos the carpentry works have not officially started yet. I have been sourcing for my bathroom and kitchen accessories over the past few weekends, quite pleased that I have gotten all the necessary stuff, feeling very accomplished! :)
Shower kerb in master bedroom's bathroom is up!
Common bathroom's shower kerb
Electrical works in master bedroom
Another view..
Skirting is also up! This is my common bedroom.
Another view of my common bedroom
Kitchen
Another close up view
Power point for my fridge
I added another power point for my service yard (opposite the washing machine), this is for my garment steamer.
Electrical works for my living room's ceiling, 1 point for my fan, 2 points for my track lights (TV side) and 1 point for my pendant light (dining table side).
Electrical works done at the TV console feature wall.
Last but not least, my feature wall is finally completed!!
So pretty! :wub:
Glad that I didn't went ahead with the craftstone brick walls..
Day 47
Hi everyone. I went to my new place on Sunday to have a look at my deliveries. Got a shock when I saw a worker lying in my living room, he's here to paint my ceiling. I only confirmed my ceiling paint on Saturday and my contractor has sent down a guy on a Sunday to begin the painting! After the painting is completed, electricians can proceed to install all my ceiling fans.
Lots of deliveries over the past 2 weeks. The state of my master bedroom right now haha!
Skirting at the entrance
The paint used for my ceiling. Decide to opt for a better paint instead of the standard Matex that most contractors/ID used.
Fans
I bought a total of 4 ceiling fans, 1 for living room, 1 each for the two bedrooms and 1 for the kitchen. Decide to forgo standing fans as they take up too much space and it will make my 3 room BTO even more cramped.
Here are the fans that I have bought:
Living room: Crestar Rainlite Polycarbonate in 50 inches with LED light (White)
Initially I was adamant in getting KDK since I have been using KDK in my current home and it has been going strong for more than ten years. Unfortunately, KDK fans do not come with 3 tones light so I have to forgo KDK. I chanced upon Crestar at Chan Huat and fell in love with the rainlite series,  especially the design of the holder where the motor is housed in. In addition, the fan comes with 3 tones LED lighting.
Price: S$385 from Chan Huat Lighting
Bedroom: Crestar Rainlite Polycarbonate in 43 inches with LED light (White)
I got the same design for my two bedrooms as well, as I wanted a standardised look throughout the entire house. I chose white for all the fans as my head will get giddy seeing something spinning at the ceiling lol.
And Kudos to Chan Huat's staff, I went down twice and was served by 4 different salespersons. All of them were very helpful and approachable!
Price: $365 from Chan Huat Lighting
Kitchen: Vento Fino II (Chrome with oak blades)
I definitely need a fan in the kitchen! Can't imagine cooking in a stuffy kitchen. This fan needs no introduction, this is a designer fan and I can buy the above 3 ceiling fans for almost the price of a Vento Fino II.  I was so upset that this fan is so expensive but am adamant in getting the fan. I was advised to get the KDK wall fan with the super old school grille thingy cos it only cost about $100, but no way! The design does not fit my Scandi theme at all and I hate cleaning the grilles!  Thank goodness JB has quite a few shops selling the Vento Fino II and I managed to get it for less than S$300! I'm super in love with the fan, it's so pretty in real life, especially the wooden blades!
Price: RM899 from HT lightings
Plumbing fixture
I will talk about the plumbing accessories that I have gotten last month. It was so stressful and overwhelming as there were so many different shops and models out there, where do I start?? Thank goodness after weeks of hunting, I have found all my desired accessories!  Got so obsessed with taps and basins til the extent that nowadays when I go to public toilets, I will take notice of the brand of the taps and sinks. :lol::P
Taps
Before the start of renovation, I have already made up my mind that all my taps are gonna be either grohe or hansgrohe. Good quality taps plus they come with 5 years warranty, I would rather pay more than having to replace them once every few years should I get the not-so-good ones. Moreover, I got all my grohe and hansgrohe stuff on promo price,  very happy that i got a good deal.
Kitchen sink tap: Grohe BauCurve Single-lever sink mixer 1/2"
Price: $171 from Bathroom Warehouse
Service yard laundry sink tap: Hansgrohe Focus E kitchen tap with 360° swivel spout
Price: $152.35 from Bathroom Warehouse
Master bedroom and Common bedroom's bathroom basin tap: Grohe Eurostyle Single-lever basin mixer 1/2" XL-Size
Got the same tap for both bathroom, and the XL one to fit my large basins.
Price: $299 from Viva Neuva
Common bedroom shower system: Grohe Euphoria 110 Massage Shower Rail Set 3 sprays
Price: $149 from Bathroom Warehouse
Common bedroom shower mixer: Grohe Eurosmart Cosmopolitan Single-lever bath/shower mixer
Price: $150 from Bathroom Warehouse
Master bedroom shower system: Grohe New Tempesta Cosmopolitan System 200 Shower System
I wanted a rain shower for my master bedroom toilet and this was a steal! The original price was retailing close to $1.5K!
Price: $599 from Bathroom Warehouse
Kitchen sink: Adamas Bathroom in-house brand
I wanted a Blanco sink but I didn't manage to find one that can be undermount. Got this sink because of it's unique shade, it's in between graphite and stainless steel kind of material? The salesperson told me that this is made of stainless steel but coated with another layer of material (can't remember the name) that makes it looks like graphite from certain angle. Due to my small kitchen, my sink can only be about 600mm.
Price: $430 from Adamas Bathroom
Service yard laundry sink: Galassi wash tub
I need a laundry sink for my service yard to wash my delicate clothings and shoes, will be building a cabinet below the sink..
Price: $388 from Sim Siang Choon
Common bathroom basin: H+M counter top basin
Oblong shape, perfect for my common bathroom.
Price: $98 from Bathroom Warehouse
Master bathroom basin: Art Ceram coral basin
Fell in love with this lovely peach colour! When I saw this sink, I'm like 'Just take my money!!!!'. :lol::lol::lol:
Price: $436.08 from Bathroom Warehouse
Overall, I'm quite happy with all the shops that I visited, good service and were happy with all of my purchases. The only shop that left a bad impression was Bathroom Warehouse. I visited the Changi and Bukit Merah branch and found that the services are quite inconsistent. I visited the Bukit Merah branch in the evening last month to place my order, all the prices were quoted wrongly when I asked for a final quote before payment. For instance, prices quoted to me vs prices on display vs prices in the system are inconsistent. I have to check each item one by one, triple check all the pricings before I made my payment. Service was slow and it was so frustrating.
