ekrose
Help Needed - Advice On My Quotation - New 4-rm Hdb
hi, sorry I am new to this forum, hence I need all of your advice/comments on my quotation.
Below is my quotation for a new 4 room HDB. Please help me see if my quote is reasonable and what other stuffs are needed but are left out in this quote.. Thanks a lot for your help! Really appreciate it. :)
Quotation:
A Masonry Works
1 Supply & lay heavy duty homogeneous flooring @ living, dining hall with skirting
2 Supply & lay heavy duty homogeneous flooring @ household shelter area
3 Supply & lay laminated flooring for all bedrooms with skirting
4 Construct Cabinet, fridge and washing machine base
5 Construct shower kerbs at both bathrooms
B Ceiling Works
1 Supply & install L-box cornices ****/Dining
2 Supply & install false ceiling at passageway
C Carpentry Works
1 Design and Fabricate 20ft top + bottom kitchen cabinet by using postform doors
2 Design and fabricate 10ft solid surface worktop
3 Provide designer handles, double layer drainage tray and cutlery tray
4 Provide 1 pair of clear/sand blast glass panel
D Plumbing Works
1 Extend copper piping for new kitchen sink area
2 Extend copper piping for new washing machine area
3 Connect inlet & outlet pipe for sink & washing machine
4 Install 1 no. of storage heater (provided by owner)
5 Install 2 sets of bathroom accessories (provided by owner)
E Painting Works
1 Painting of walls and ceilings for whole house by using ICI paints
F Misc:
1 Provide acid washing
2 Provide floor protection cardboard $ 12,888.00
G Additional Works
1 To supply & install 1 nos 7ft tv console by using selected laminated finishing $ 840.00
2 To supply and install 4ft kitchen cabinet by using selected laminated finishing $ 460.00
3 To supply and install 1 nos dining table by using selected laminated finishing $ 1277.00
4 To top-up 5ft wardrobe by using selected laminated flooring $ 1250.00
5 To supply and install 1 nos shower screen to master bedroom $ 600.00
H Discounted items/Free gifts
1 To supply and install 5ft wardrobe by using laminated finishing c/w 1 set of 3 tier drawers F.O.C.
2 To supply and install 2nos smart drawers (with glass panels) to wardrobe F.O.C.
3 To supply and install lock(s) to wardrobe F.O.C.
4 To supply and install 1 nos pull out mirror to wardrobe F.O.C.
5 To up-grade cabinets hinges to Irex hinge F.O.C
6 To supply and install Toshiba system 3 air-con F.O.C
Total Package Cost: $17,315.00 (w/out GST)
$ 18,180.75 (with GST)
not sure if it's standard pricing
but this is what my contractor quote me (EA)
not doing tiling works though
Below is my quotation for a new 4 room HDB. Please help me see if my quote is reasonable and what other stuffs are needed but are left out in this quote.. Thanks a lot for your help! Really appreciate it. :(
Quotation:
A Masonry Works
1 Supply & lay heavy duty homogeneous flooring @ living, dining hall with skirting (what kind of tile can you select? list price or cost price)
4 Construct Cabinet, fridge and washing machine base (washer base $90, cabinet base $180, fridge base $90)
B Ceiling Works
C Carpentry Works
1 Design and Fabricate 20ft top + bottom kitchen cabinet by using postform doors ($90pfr with solid ply door c/w ABS trimming)
2 Design and fabricate 10ft solid surface worktop ($100pfr granite worktop)
3 Provide designer handles, double layer drainage tray and cutlery tray (included in cabinet price)
4 Provide 1 pair of clear/sand blast glass panel (included in cabinet price)
D Plumbing Works
1 Extend copper piping for new kitchen sink area ($100)
2 Extend copper piping for new washing machine area ($80)
3 Connect inlet & outlet pipe for sink & washing machine (included in extension of piping)
4 Install 1 no. of storage heater (provided by owner) (how about the hot water piping? included as well? to how many points?)
5 Install 2 sets of bathroom accessories (provided by owner) (FOC)
E Painting Works
1 Painting of walls and ceilings for whole house by using ICI paints ($1,350 all internal walls with ICI medifresh 3-in-1 or equivalent, $150 for patching up wall grooves and $100 for painting all doors, frames, piping in gloss paint)
F Misc:
1 Provide acid washing ($80 for twice)
2 Provide floor protection cardboard (FOC) $ 12,888.00
G Additional Works
1 To supply and install 5ft wardrobe by using laminated finishing c/w 1 set of 3 tier drawers F.O.C. (what material, what kind of door etc?)
2 To supply and install 2nos smart drawers (with glass panels) to wardrobe F.O.C. (smart drawers as in blumotion runners or what?)
5 To up-grade cabinets hinges to Irex hinge F.O.C (one blum hinge is $8)
6 To supply and install Toshiba system 3 air-con F.O.C (think cost around $1600 including installation i.e. class 1 insulation, grade 23 copper piping and new CU pipe)
$ 18,180.75 (with GST) get them to absorb the GST
my two cents worth :)
Edited by applefreak
Quotation:
A Masonry Works
For tiles: what will be the dimension on of it. And how much is psf?
Laminated flooring: What is the brand and the quality given from the renovator?
Washer and fridge base: will it be up to owners measurement as to be fair to the owner on what item had been purchase.
B Ceiling Works
C Carpentry Works
D Plumbing Works
copper pipes:
dont have connections for both bathrooms?
it consists hot and cold or cold only?
E Painting Works
what will be the quality of paint and also how many colors are there?
F Misc:
dont have a general wash?
G Additional Works
Got drawers? All laminated finished? no combination of glass?
What is the dimension given?
How thick is the material?
What are the materials of table legs given?
Overall, What is the selected brand of laminate can choose from?
nothing comes free. The more things that are free then u will have to take note on the materials and the quality of material too. :)
Edited by Devilaz
Hi applefreak & devilaz.. thanks for your comments/advice...
hmm.. most of the things you guys commented.. my id did not really specify them...
as for the laminated flooring.. he said tt he'll be using his own company's laminated flooring.. he showed the sample to me when i met him for appointment the other time.. the name is alsapan flooring..do u know of this brand? is it good?
if i remember correctly, the price quoted on the sample is somewhere ard $6.50... i guess tt's the price of the laminated flooring? but he did not tell me the price of the homogenous tiles and i had forgotten to ask him.. i'll ask him the next time though..
as for the paints, i was told there will be 3 coats (excluding the base)... hmm... guess my quotation is still v vague.. and there are still a lot of things that i needa to ask him about..
Thanks for your advices! :sport-smiley-004:
change id pls
Erm, if you think there is anything wrong with the current ID that our forummer has or that maybe you can do better, please state so.
Such a statement like 'change id pls' is quite useless and does not help anyone at all... :sport-smiley-004:
personally, i feel that if you are not taking a package
it'll be good to have itemised quotation where every item is specific
e.g. supply and lay (size e.g. 600 x 600) (homogenous or porcelain or ceramic) tiles ****, dining with skirting (cost in absolute dollars) (max price psf)
so the item should read
supply and lay 600 x 600 porcelain tiles **** and dining with skirting $3000 (max $3psf)
for carpentry items, it'll be good if the entire length, max height, material (solid ply/ply/chip-board), laminate (brand, country etc) etc listed down as well
quite a few forummers had IDs / contractors who went back on their words simply because it's not stated in the contract / quotation
Hi all, i had engaged Aven from G Plan. These are what i going to do for my new 85m2, 4 room flat. Is the price reasonable?
1) Granite flooring with skirting for living/dinning and three bedrooms
2) Homogenous tiles for store room
3) Base for kitchen cabinets, fridge and washing machine
4) 8ft sink and stove support come with homogeneous tiles and wooden doors
5) 18ft top and bottom kitchen cabinets in laminate finish with ABS trimming
6) 9ft solid surface top
7) Supply & install aluminium bifold door @ kitchen entrance
8) inlet and outlet piping for kitchen sink and washing machine
9) Labour to install water heater and bathroom accessories
10) Construct false ceiling in living and dinning area
11)Supply & apply 03 coats of ICI Dulux to all internal walls & ceilings
12) Construct wall feature come with tv console in laminate finish
13) Construct 10ft wardrobe with wooden sliding door with false wall
14) Supply & lay protection sheet
15) Clean up whole unit with chemical
Total cost: $16,500
It will be good to specifiy on each individual items.
At least will know what will be the cost for each individual things. :)
Hi Ekrose, have u try to source for other contractors or id firms? Cos these will provide u with better comparison as each id firms will have their way of display their quotations. :)
Btw have you signed the contract with ur contractor? :dunno:
This is the detailed contract:
1 Flooring Finishes
1.1 Granite Black tiles at foyer area with skirting $690
1.2 Granite floor tiles 60x60cm for living/dinning hall with skirting $2030
1.3 Granite floor tiles 60x60cm for 3 bedrooms with skirting $3580
1.4 Homogeneous floor tiles 30x30cm matt textured for storeroom $320
1.5 Raised cement base with tiled skirting for kitchen cabinet $380
1.6 Raised cement base with tiled surface for fridge base and washing machine base $220
2 Wall finishes and ceiling works
2.1 Painting for whole house/ceiling and water pipes with ICI emulsion paint $1150
2.2 False ceiling for living/dining hall $770
3 Plumbing works
3.1 Installation of instant water heater and connection of inlet/outlet single pipe for bathroom $90
3.2 Installation of kitchen sink and tap and connection of inlet/outlet single pipe $140
4 Door
4.1 Aluminium bi-fold door for kitchen $200
5 Living hall
5.1 Tv console with laminate finish and ABS profile doors 1700mm $600
5.2 Feature wall for Tv with laminate finish 1700mm x 1200mm $560
6 Kitchen area
6.1 Kitchen cabinets top and bottom cabinet section with laminate finish & ABS profile doors 16 feet $1600
Utensil tray for fork and spoon
Aluminium dish drying rack
Selected designer handles
6.2 Solid surface work top (8ft) $520
6.3 Concrete support with hollow blocks and selected tiles finish for sink and stove (8ft) $1120
6.4 5 swing door for concrete support with laminate finish & ABS profile doors $430
7 Master Bedroom
7.1 Feature wall for bedhead with gypsium board finish 10ft length x full height $510
7.2 Build-in-full ht wardrobe with sliding/swing doors in laminate finish & ABS profile doors (10ft) $2100
8 Misc
8.1 Supply & lay protection sheet FOC
8.2 Clean up whole unit with chemical FOC
Total cost: $17,030
Discount: $530
Final cost: $16,500
Hi Ekrose, have u try to source for other contractors or id firms? Cos these will provide u with better comparison as each id firms will have their way of display their quotations. :jawdrop:
Btw have you signed the contract with ur contractor? :notti:
Hi Cantona,
ya, i've got 3 quotations so far.. but one is way above my budget, and the other budget seems ok.. but felt tt the id was not really gd... design wise not really practical.... am waiting for another quotation from another id but till now still no news from him... will call him again to ask for quotation... as for the one who quoted me the quotation in this post... he seems to be able to 'click' with us and understands what we want in the designs... n he seems quite earnest n sincere n knows what he is doing...
i havent sign the contract with him yet..as in the official one.. but i've paid a deposit of 200 for his 3-d drawings though.. i paid the deposit at one of those fairs at expo,... cos got promotion package...
i still havent meet him for further discussion on the materials n cost, but guess if he's still not really upfront with the materials, i am prepared to forefeit the deposit and find another whos better...
actually i hope to sign up before the gst hike... so i paid the deposit first.. but out of the 3 ids i've talked to.. this one seems to be the 'right' person... sigh.. :D
yo rose
u might want to give my id a try. mine's a em n i spent ard 30k renovating. things like re-vamp of the whole kit n 3 toilets (inclusive of tilings, WCs, plumbing, gallon heater, wiring, shower screen, tempered glass door @MT, bi-fold door @ CT, basins, rubbish chute, carpentry works), re-grind & re-varnish of parquet flooring @ 3 bedrooms, passageway, staircase n hand railings, re-polishing of marble flooring @ living n dining, hack some walls, re-erect some walls, plastering, painting, paritions, haulage, debris removal, acid wash, general wash.
he's quite responsive, easy to build rapport, price reasonable (e other 3 co i went, quote me between 35-38k), workmanship not bad. email me if u're interested, zongfu24@yahoo.com.sg
