Dishwasher Drainer Cabinet Hydraulic Hinges
Anyone uses the hydraulic hinges. Is it durable? I was in my col's house and seems like the hydraulic is not so smooth, is it poor workmanship or is it the hydraulic itself?
Any alternative to solve this? Thanks.
  • 11 months later...
Where to buy hydraulic hinges for those cabinet that are open upwards e.g dish rack?
Due to wear and tear, most probably the hydraulic plunger has to be changed. Safest way is to remove it and bring to hardware shop to source for similar one.
Hardware shops like homefix, self-fix or you can try hardware shops
along Geylang road (T*i Seng H*rdware) or yellowpages.com.sg
I suppose is just drill & fix into the same holes where the old ones used to be? Else the cabinet will hv lotsa holes...
Yup..find the item with exact holes position but not necessary same brand.
no need to drill as it will enlarge the holes plus the screws used are self tapping. Just screw it in.
Any idea how much will these plungers be?
Ermm...Not very sure..
You hv to consider Made in China, Taiwan and etc..Plus brand lor..
But i think durability is still far most important. As i don't think you would want to change it very often..I PM you a hardware shop contact and u try asking??
I just installed my kitchen cabinets 6 months ago... i have 3 cabinets with these plunger, now 2 of them are spolit... duno should blame on my contractor ma... mayb they use inferior products... so i muz standby in case they are spolit again... cos i always open & close very often....
Yes please pm e contact. =)
Ya.. I think the quality is indeed compromised. Maybe you want to check with your ID whether he can replace for FOC?? I supposed there is a after reno warranty. But probably he would say it is not his fault as warranty does not include wear and tear... :dunno:
Usually ID gives normal hinges and etc to maximise their profit margin. Thats where we suffer from..
