GoodVictor
Wav files converting to Audioloop
I have a problem
When I edit an audio clip in Studio One, I find that the clip is converted to an Audioloop format rather than a wav format when I export the clip. The problem is that I am exporting the clip in order to store the clip on my Boss RC3 pedal (that only reads wav files) how to I prevent these clips from becoming Audioloop files or alternatively convert these files back into wav?
Any advice greatly appreciated
What is the method by which you export the files? Maybe this is where the problem begins. You can select all exported files from the editor's settings to have the wav extension, or you can choose this option when the dialog box opens. You could also use an online application before that to change the extension of audio files as you need. I use https://convertr.org/wav-to-mp3 to convert wav files to mp3 audio files, but you can definitely do the opposite there.
