Coverting 3rd toilet at yard to storage
Hi, anyone converted your 3rd toilet at yard to storage by removing the toilet bowl? Can share experience?
Just remove the bowl and plug the drain pipe? Can diy?
if you know how to DIY can DIY. need to seal the sanitary waste pipes properly as well as terminate the water supply..
I think can diy. But cant seem to find the plug to plug the drain pipe online. Would you be able to advise where to find the right seal?
if you can't find the plug, then just put newspaper or styrofoam into the pipe then pour cement in to create a seal. this is a common method done by contractors
