summerholiday
Which Aircon Did You Use?
Mine is Toshiba: 3 inverters and 1 non-inverter from Etronin A/C & Electric. All inclusive @ $3450 in June 2006.
Edited by gendon
Mitsubishi Starmex System 4 Inverter R410A
Model: MXY-4A28VA/
MSXY-GA10VA x 3
MSXY-GA26VA x 1
BTU/HR: 26,000
Materials include:
1. Copper tube 1.2: x 0.61 G23 (12.70mm)
2. LF PVC Pipe Drain 13mm x 2.9m
3. Armoflex Tubing 3/8" x 3/8" x 2m (then i read the singapore aircon blogspot and i ask the uncle to change to 1/2". he said ok he will change. then when i go check, i see some 5/8", some 1/2", some 1/4". give some take some, ok lah)
c/w stainless steel bracket
+ dismantle + remove all old trunking + aircon
+ Unlimited site survey/installation trips
Total Amount: $3,800
Chye Lee Airconditioning & Electrical Services at Block 446 Hougang Ave 8.
Have the same question. Looking for system 2 with small air-con unit if possible as don't want to occupy space due to height limitation.
Any Japanese brand/ model to recommend? Any shop that is well known for workmanship and good material used.
I don't want to end up leaking problem which cause headache later. cheers !!
