Laminate Repair
is repair work on laminate possible? can change out the bad areas? thanks.
Be more specific please............
for example, deep scratches.. can it be repaired thru replacement of the bad strip?
Possible but need to remove a much bigger area for work access; eg if you need to replace 1 pc at the middle of the room, probably 5 pcs on both left and right and 1 pc from front and back of the affect pc. Don't ever expect the finishing of the completed rectification work to be perfect unless you relay the whole room
