Toshiba Inverter Sys 3 Best Price !
Finally after comparing prices, installation workmanship etc, I bought my Toshiba Inverter sys 3 from Fairprice Xtra @ AMK HUB! Got a good buy! Extremely good price...
All in $2240 .. (after some rebates etc)
Toshiba Inverter System 3 (outdoor unit made in japan)
6years warranty on compressor (instead of the usual 5)
1 yr warranty on fancoil
15 months warranty on piping
Unlimited piping
23mm, Grade 1 insulation
Unlimited piping
wow...that's very good price.. :(
Hi All,
I'm consider to take Toshiba inverter rather then Mit non-inverte (at least can save energy).
Between, i heard that Toshiba invete's gas r much more expensive then others aircon's gas?
It's that true?
Hi All,
It's that true?
Nope not true, the gas used not determined by brand. Most brand Inverter using R410A and non-Inverter using R22
R22 --> Use in most non-inverter system. Going to phase out in few years time.
Harmful to Ozone
Now gas refill cheaper but maybe more expensive later
R410A --> Newer gas, used in Inverter system and some new Non-inverter sys.
Gas refill more expensive, gas price expect to drop when it get more n more common.
Ozone friendly (Save the earth!)
Edited by cookie
Hi cookie,
Oh thanks for the info.
So means all of the inverte MUST use R410A?
Any idean how much $ different between R22 and R410A?
Thanks.
wow...that's very good price.. :thumbs up:
Yes Indeed! Gain city quoted me $2459. The good price $2240 is derived from $2459 (Fairprice matched Gain's Price) and deducting the rebates I get fm fairprice & Citibank plus the ntuc link points....
hi audreymarilyn,
The price it's not included bracket right?
So the original price it's $2459 oh?
oh.. i see... thanxx
But the btu very low compare to starmex inverter.If ur rooms r big then got problem cooling if three room on at the same time.
the following are a lists of air-con retailers that you can try calling them and faxing them your floor plan for sizing caln and quotation. you can also ask them for advice on what is the best combination.
1) national climate change committee
this is website for your infor on air-con
http://www.nccc.gov.sg/energylabel/checklist.shtm
2) toshiba
http://www.toshiba.com.sg/HA/Content/Categ...dc503f2ef404802
3) LG
a) http://www.nccc.gov.sg/energylabel/lge.shtm
b) http://sg.lge.com/support/dealerList_north.jsp#aircon
3) mitsubishi heavy industries
http://www.nccc.gov.sg/energylabel/mitsubi...industries.shtm
4) sharp
http://www.nccc.gov.sg/energylabel/sharp.shtm
5) fujitsu
http://www.nccc.gov.sg/energylabel/fujitsu.shtm
6) general
http://www.nccc.gov.sg/energylabel/general.shtm
7) mcquay
http://www.nccc.gov.sg/energylabel/mcquay.shtm
8) panasonic
a) http://www.nccc.gov.sg/energylabel/panasonic.shtm
b) http://panasonic.com.sg/web/Contents/MainCont.asp?ContId=112
9) hitachi
http://www.nccc.gov.sg/energylabel/hitachi.shtm
10) daikin
http://www.nccc.gov.sg/energylabel/daikin.shtm
11) mitsubishi electric
http://www.nccc.gov.sg/energylabel/mitsubishielectric.shtm
12) samsung
http://www.nccc.gov.sg/energylabel/samsung.shtm
air-con retailers cum installers
1) coolserve
http://www.coolserve.com.sg/htmdocs/coolAd...visor.asp?id=10
2) best tech
http://www.besttechaircon.com/
3) Etronin Air-Conditioners & Electric
Blk 633 Veerasamy Road #01-128 Singapore 200633 Tel: 62948931
4) hong tar
http://www.hongtar.com.sg/
air-con certified installers:
www.bca.gov.sg/academy/Trained_Installers.aspx
hope the above infor helps.
these are the quotes i was given for toshiba.
toshiba system 3 inverter (got this combination as i need to cool a big hall and MBR) and i am installing 2 sets of system 3 (if i do decide on system 3)
outdoor unit: RAS-3M23YACV - 24,000BTU/Hr x 1 unit
indoor unit: a) RAS-M10NKCV - 9,000BTU/Hr x 2 unit +
b) RAS-M13NKCV - 12,000BTU/Hr x 1 unit
prices do not include bracket coz i hv concrete aircon ledge:
a) h@ng ta - S$2,780
b) Best tech - S$2,653.60
c) mega - S$2,550.00
d) hong huat - S$3,103
e) federal - S$2,398.00
toshiba system 4 inverter (if i get this combination, i would need to get 1 more single split system coz not enough for my hm)
outdoor unit: RAS-4M30YACV - 30,000 - 34,000BTU/Hr x 1 unit
indoor unit: a) RAS-M10NKCV - 9,000BTU/Hr x 3 unit +
a) h@ng ta - S$3,730
b) Best tech - S$3,456.10
c) mega - S$3,400
d) hong huat - S$3,531
e) federal - S$3,400
if bracket is required, the prices are:
a) h@ng ta - S$120
b) Best tech - S$150
c) mega - S$120
d) hong huat - S$100
e) federal - never state
all piping and insulation base on manufacturer's spec. basically its either, armaflex, k-flex, thermaflex, totaline insulation etc.
cu piping as per manufacturer's specs.
piping and cabling all in pvc trunking.
these are the quotes i was given for mitsubishi.
mitsubishi system 3 inverter (got this combination as i need to cool a big hall and MBR) and i am installing 2 sets of system 3 (if i do decide on system 3)
outdoor unit: MXY-3A28VA - 30,000BTU/Hr x 1 unit
indoor unit: a) MSXY-GA10 - 9,000BTU/Hr x 2 unit +
b) MSXY-GA13VA - 12,000BTU/Hr x 1 unit
a) h@ng ta - (mitsubishi electric)S$2,900 / (mitsubishi heavy) S$2,680
c) hong huat - S$2,950
d) all best - S$2,731
e) best denki - S$3,299.00
f) double-h aircond - 3,150.00
g) golden harvest
h) systematic airconditioning - S$3,100
mitsubishi system 4 inverter (if i get this combination, i would need to get 1 more single split system coz not enough for my hm)
outdoor unit: MXY-4A28VA - 30,000BTU/Hr x 1 unit
indoor unit: a) MSXY-GA10 - 9,000BTU/Hr x 3 unit +
b) hong huat - S$3,650
a) h@ng ta - S$120
b) hong huat - S$100
c) all best - S$150
d) best denki - S$110
e) systematic airconditioning - S$100
hi audreymarilyn,
ya its $2459 original but does not include bracket coz my ea comes with aircon ledge.
Hey how much reno u doing n how much did 3d quote u? i'm still deciding if i should go with 3d or max image... edmund is fm which branch? i've spoken to jeremy fm kovan.
How big is ur jacuzzi and where are u placing it? will it fit into the mbr toilet? wat is the usual price of the jacuzzi which you got?
