Silviagirl
Mbr Toilet
Hi all;
Need some help here, i know it is not good to have toilet in MBR(in FS), but anyhow, nowadays most HDB come with it originally. My MBR has one toilet, we do not plan to remove it (as it is quite convinient lo..) but in FS, it is not good, especially when the toilet bowl is facing the bed!!(pls check the layout i draw)
can anyone give some advise? :)
wahlao.... :)
maybe shift bed to cupboard 's side?
keep toilet door always CLOSED or put curtains, green colour ones(makes sure green does not chiong with your bazi).
no tv....lcd/plasma ok. - or cover with cloth when not in use.
wahlao.... :yamseng:
Hi MaCe;
Cant shift as no matter how i shift, still will face the toilet door one... :dunno:
May i know why must use green colour?
Can i put some small plant inside the toilet?
My friend asked me to put a windchime on the top of toilet door, does it help?
Hi MaCe;
Cant shift as no matter how i shift, still will face the toilet door one... :yamseng:
thanks :dunno:
any remedy is actually not a remedy...it only cuts down the effect.
hopefully both of you needs WATER, then it became a blessing instead of a "curse".
always keep toilet clean and dry at all times. close the door when not in use...etc
if you shift the bed, at least the door face your legs instead of your whole bed.
may i know what is the effect?
the bad thing is i cannot have too much water :yamseng:
shift the bed head to the cupboad there then my leg will face the window liao.. also not good right? haiz...
alternatively, if you have not started your renovation
maybe you want to consider shifting the basin to the existing door area
and open the basin area as the new door :)
Hi applefreak;
got think of it too,but budget lo... thats why think of finding the most economic way ... :notti:
use another room as mbr.
if you already know you cannot have too much water. the toiletbowel is not just spilling out water, dirt also.
health will be a problem, for your case X10
Hi Mace;
Means, no way to prevent other than change room right? ;)
The toiletbowl so terrible one ah? :(
Hi Mace;
nothing to do with ghost movies....those dirty things loves to enter your house from there.
if toiletbowl is facing other than the toilet entrance , then still not so bad.
Edited by MaCe
then always close the toiletbowl cover will that help?
got think of changing the toiletbowl direction, but my house is the top, contractor said cannot change :good:
cannot change - for hdb.
if you insist on sleeping in that room, then always close door + close toiletbowl cover.
if possible put a plate of sea salt on top of the toiletbowl.
sea salt can buy from those fish shop that sells marine fishes.
HI Mace;
Thanks for the advise, may i know what is the function of sea salt, err.. sea salt is the salt from the sea??? :bangwall: hehe..just want to make sure wat i think is correct....
HI Mace;
Thanks for the advise, may i know what is the function of sea salt, err.. sea salt is the salt from the sea??? !! hehe..just want to make sure wat i think is correct....
sea salt = from the sea
table salt = from the table !!
