apprye
*need Help On A Quotation From Id*
Just got this quote for my 5rm Premium in Jurong West St 64... What do you guys think of the pricing? Budget was $12k, in the end raised to $15k.. Like nothing much done and it's already at $22k... :( Any items that I can bargain with the ID? Meeting them tomorrow in the evening after work....
PAINTING WORKS
1 $1,000 ICI Painting for Whole House Max. 5 Colours
2 $150 Oil Painting for all Pipes, Bedroom Doors & Door Frames
3 $150 Sealer Undercoat for L-Box Ceiling
MASONRY WORKS
4 $150 Construct & Erect 50mm Kitchen Cabinet Base with Side Tiling
5 $80 Construct & Erect 50mm Fridge Base with Full Tiling
6 $80 Construct & Erect 50mm Washing Machine Base with Full Tiling
ELECTRICITY WORKS
7 $1,430 Supply & Install Downlights with Additional Electricity Points in Hall &
Dining Area @ $65 x 22 pts
8 $180 Supply & Install Flourescent Light Tubes in Cove Light Holder - $45 x 4 Nos.
9 $130 Shift SCV Point in Living Rm
10 $70 Shift Double Power Point in Living Rm
11 $0 Supply Labour to connect cooker hob in Kitchen Cabinet
12 $0 Supply Labour to connect cooker hood in Kitchen Cabinet
13 $0 Supply Labour to connect Door Bell
CEILING WORKS
14 $750 Construct & Erect L-Box Ceiling in Living Rm & Foyer
15 $180 Construct & Erect L-Box Ceiling in Dining Area
16 $300 Construct & Erect U-Box False Ceiling to Hang Dining Light in Dining Area
17 $280 Construct & Erect Cove Light Holder at Household Shelter
PLUMBING WORKS
18 $0 Supply Labour & Material to Install Inlet/Outlet Pipes for Kitchen Sink
19 $0 Supply Labour & Material to Install Inlet/Outlet Pipes for Washing Machine
20 $0 Supply Labour to Install Bathroom Accessories
21 $80 Supply Labour to Install Instant/Solid Heater
CARPENTRY WORKS IN LIVING ROOM
22 $1,200 Design & Fabricate Household Shelter Feature Wall in Laminate Finish
& Full Mirror Design - 5.5 Ft
23 $800 Design & Fabricate Full Height Shoe Rack Adjourned to Household
Shelter - 3 Ft
24 $1,500 Design & Fabricate Feature Wall 6 Ft with TV Console 6 Ft in Laminate
Finish & Stainless Steel Design
25 $580 Construct & Erect 1 1/2 Ft Height Platform Plankwood at Balcony
26 $450 Design & Fabricate Storage Pull-Out Drawers with Glass Design beneath
Platform
27 $400 Supply & Lay Laminate Flooring on Platform at Balcony
28 $680 Design & Fabricate Fixed Panel Feature Wall to Cover Bedroom Doors
in Stainless Steel Trimmings & Laminate Finish - 3.5 Ft ($680)
29 $450 Design & Fabricate Wooden Sliding Door Adjourned with Feature Wall
to Cover Bedroom Doors in Stainless Steel Trimmings & Laminate Finish ($450)
CARPENTRY WORKS IN MASTER BEDROOM
30 $2,430 Design & Fabricate Walk-in Wardrobe with Inner Ply Laminate - 9 Ft
31 $1,400 Design & Fabricate Plywood Partition with Laminate Finish to Seggregate
Walk-In Wardrobe with Fixed Panel Partition & Sliding Wooden Door
32 $1,900 Design & Fabricate Queen Size Bed Frame with Head Board & 2 Side
Tables
CARPENTRY WORKS IN KITCHEN
33 $2,800 Design & Fabricate Kitchen Cabinet (Top & Bottom) - 28 FT
**Complete with Aluminium Designer Handles, 2 nos. Frosted Glass,
1 no. Stainless Steel Dish Rack, 1 no. Cutlery Tray, Cabinet Door Stopper
Enhancer
34 $840 Supply & Install Solid Surface Work Top - 14 Ft
35 $850 Supply & Install Tempered Sliding Glass Door at Kitchen Entrance
PARQUET FLOORING
36 $550 Polish & Lacquer Parquet Wood Flooring in 3 Bedrooms
TOILETS
37 $400 Supply & Install Powder Coated Aluminium PVC Panel Bi-Fold Door at
2 Toilets - $200 x 2 Nos.
MISCELLANEOUS
38 $0 Lay Corrugated paper for floor protection
39 $0 Haulage & Removal of Debris
40 $0 Acid wash for Whole House upon Completion
Total: $22,240
Does anyone know if a 1.5 ft platform by the window is allowed by HDB? All the IDs that I approached told me that it's not approved, but this ID told me that it's ok... :( Dunno who to believe.....
PAINTING WORKS
MASONRY WORKS
ELECTRICITY WORKS
CEILING WORKS
PLUMBING WORKS
Shelter - 3 Ft
Platform
Tables
Enhancer
PARQUET FLOORING
TOILETS
MISCELLANEOUS
Total: $22,240
May i know who is ur ID?
Hi Apprye,
With regards to your question on raised platform, not sure if this is applicable here, but you may wanna take a look at
http://www.hdb.gov.sg/fi10/fi10205p.nsf/WP...ed?OpenDocument
Under their examples, one of them says,
"Raising of floor level exceeding the allowable thickness of 50mm (inclusive of floor tiles) using concrete"
Or go thru' this?
http://www.hdb.gov.sg/fi10/fi10205p.nsf/WP...Menu=Guidebooks
Btw, why do you need such a high 1.5ft platform (~45cm) by the window? Are you using it as your bed frame or it's going to be a bench with cushions?
I'm sure you would have gotten quite a number of quotations right? So, is this the cheapest?
Btw, can you PM me who is the contractor that provides you with this quotation?
Regards.
IF ur budget is only $12K, why r u still doing LBox? just doing the kitchen cabinets and masterroom wardrobe and bomb shelter + 2vanity cabinets for ur toilets will be ard $12K liao. provided u do the painting of the hse by urself. if u wan everything listed in ur quote it can never be $12K.
frm wat i see, they are like giving u many items FOC, it looks quite worth the price.
but i feel tere are many tings u can cut down on, like the L box and shoe rack thing, but it's up to individual needs la.
PAINTING WORKS
1 $1,000 ICI Painting for Whole House Max. 5 Colours ok price
2 $150 Oil Painting for all Pipes, Bedroom Doors & Door Framesok price
3 $150 Sealer Undercoat for L-Box Ceilingok price
MASONRY WORKS
actually u can do suspended kitchen to save on the base cost. washing machine also no need base, u buy the brick-like thing from those d-i-y shop can liao
ELECTRICITY WORKS
Dining Area @ $65 x 22 pts usual lighting price for per additional lightpoint (including installing of light) is no more than $38
9 $130 Shift SCV Point in Living Rm ok price
CEILING WORKS
PLUMBING WORKS
21 $80 Supply Labour to Install Instant/Solid Heaterok price
& Full Mirror Design - 5.5 Fti was quoted only $750 for SIX feet bomb shelter feature wall, with mirror also, but in the end i go for plain-gloss laminated tic tac door with no mirror as it is much cheaper
Shelter - 3 Ft
Finish & Stainless Steel Design $200 pfr for no stainless steel
Platform
30 $2,430 Design & Fabricate Walk-in Wardrobe with Inner Ply Laminate - 9 Ft$200 pfr can get, if ur door is laminated with no glass or steel
Tables
Enhancer
35 $850 Supply & Install Tempered Sliding Glass Door at Kitchen Entrance mine 1fixed panel (door size) and 1 sliding only $880
PARQUET FLOORING
36 $550 Polish & Lacquer Parquet Wood Flooring in 3 Bedroomstotally unnecessary
TOILETS
37 $400 Supply & Install Powder Coated Aluminium PVC Panel Bi-Fold Door at 2 Toilets - $200 x 2 Nos.ok price
Total: $22,240
Edited by mud3210
Thank you so much mud3210 for providing your comments! :) Upped the budget so that it can be a nicer and more comfortable home to come back to after a long day at work you see...
Quite happy with their work, last Thurs confirm yesterday start work liao... :D
All the best for ur renovation and do update us with photos n ur progress. Thanks :)
