ylucy
Aircon System 3 Inverter
I need advise lei.. I am doing my flooring and hacking the wall tiles. I ask my reno contractor to remove the aircon piping and aircon. If I buy new aircon, is it included inside or there is also charges involved.
Also, when should I install the aircon, before the wall tiles of my bathroom for the piping or after the completion of wall tiles..
new pipping will be install by ur new aircon contractor is part of the package..
Run pipe 1st before tile ur wall ..if not they might have to hack away ur wall tile to make way for water pipe.
ur ID should be able to advise you this kind of thing..
aircon installation usually 2 trip
1st trip run pipping
2nd trip install compressor and fan coil
You advise me to install air-con before wall tiles, right.
Between which air-con company is okay.. I mean intend of installation and sales service.
Let me go IMM first now.. Got Bestt**h, GC , ...
Edited by kewin
since u going to imm... try visit hong tar also.. they just beside IMM about 10mins if u walk..
http://www.hongtar.com.sg/
hongtar had been doing aircon for very long... they have just install my pipping last friday..find the workmanhship of pipping reasonable good. They really put in effort to get the pipping right... not those type want to rush home and go off earlier..
Not sure whether which one is the best? Since this topic is about this. I will related to this
Aircon System 3 Inverter, Daikin vs Mitsubishi Electric
Standard Package, removal of old air-con for Free. Installation of new pipe, bracket. My package is without stainless bracket
AllB**t
StarMex - 2699 w/GST
Daikin - 2699 w/GST
GC
StarMex - 2550 wo/GST
Daikin - 2799 w/GST
B**t Tech
Daikin - 2550 wo/GST
Hong Tar
StarMex - 2870 w/GST
Daikin - 3000 w/GST
AllB**t
Daikin - 2699 w/GST
GC
Daikin - 2799 w/GST
B**t Tech
Hong Tar
Daikin - 3000 w/GST
Are u quote on the same exact model and same BTU.. price very different. Well take note of the pipping grade and size they are giving u..
I encore what tommy78 commented. Look into the fine details like "use of 1/2 inch thick class '0' thermaflex insulation for indoor unit and class '1' black insulation for outdoor unit. PVC pipe use will be 16mm and G23 copper pipe", etc...
Edited by ilmare612
I think I am going to IMM to see again ... I went to all.
I have 2 company in mind, H@ng Tar or GC, but H@ng Tar is about $50 expensive than GC.
H@ng Tar "use of 1/2 inch thick class '0' thermaflex insulation for indoor unit and class '1' black insulation for outdoor unit. PVC pipe use will be 16mm and G23 copper pipe".
Edited by kewin
Hi Kewin, wondering if u r getting daikin 71ESG or Starmex for ur flat?
Avoid All Best at all costs. Had very bad experience with them. Only get from Gain City. Workmanship and after sales service is good.
i just bought Hitachi System 3 Inverter with Nano Titanium at $2699 + $180 [upgrade piping] + $450 [aircon servicing package]
To all forumers here, DO NOT buy any air-cons from ALLBEST at IMM. Their workmanship is atrocious and their after sales service is horrible. I bought my Mitsubishi Heavy Industries system 3 aircon from them and condensation was already forming on the casing after 1 week. When I called them to check, the workers simply insert newspapers into the plastic casing. **** unprofesional. In the end, I complained to CASE and they decided to re-do the whole piping. Gave me so much headaches. Now my new unit is using Mitsubishi Starmex system 4 from GainCity. Workmanship is good and air-con has no noise at all.
I got a quote from a friend. not sure he can be trusted. here was his quote.
mitsubishi electric
2 spilt unit only
MXY-2E20VA 5.27kw
MSXY-GA10VA 2.5kw x2
price $1773 + $300 for installation. is this cheap?
5 years warranty
bracket not included cuz I am swapping my old toshiba single spilt for double spilt. the toshiba is not even 3 years old. I gave up on it. PCB board failed. replaced once DIY then louver motor failed, also replaced DIY once.
Edited by andywee
Yes I regretted getting Allbest to do my aircon.
