Water Dechlorinator With Heater
Looking for those dechlorinator type water filter with heater ..
meaning can select normal cold water or hot water...
so no need to use those hot heater flask...
can recommend me if u came across any brand...thanks
Meaning the chlorine remover medium is part of the water heater?
Hmm, I have not come across those before, would be nice if it exist.
I use another type of shower filter that is attached to the water outlet, the filter medium has to be changed every few months before it loses it's effectiveness.
Has anyone else noticed that water is dirtier lately?
One of the possible causes for hairloss and skin eczema when you shower in it.
Needless to say if you drink it direct from the tap ...
i heard it does exist ... need to do some searching around ...
meaning i can just run tap drink from the dechlorinated water after the filter.
will be good if can have hot water function for making 3 in 1 kopi as well.:P
Ooops, sorry I got you wrong.
I thought you were refering to the shower instant heater.
There are special shower head filters or tap filters for those.
If you are talking about drinking/washing tap, there is external filters that is attached to the mouth of the tap.
There are also "internal filters" that can be attached under the sink, though I'm not sure how the hot water works, might have to run 2 different pipes.
