Will The Altar Table Behind My Bedroom Affects Me?
I would wish to convert my study room to a bedroom. My mum say girls should not slp in the room whereby the altar table is directly behind your room. Is it true that bad things will happen in terms of fengshui?
Your mom is very right, understands from a temple caretaker that space directly behind altar table should keep clear of anything.
If it is a room then the person staying in the room will have their social life affected. (properly it too “ying” for sleeping, luckly mine is a storeroom behind the alter table.)
  • 3 weeks later...
it's ok
as long as your bed(rear, front,side) is not directly sharing the same wall as the altar table.
ooohh.. i think before i moved out, when staying at my mum's place, my bed was directly behind the altar, of coz with a wall in the middle.
But i would keep swifting here and there after 2 months. Nothing very much affected it seems.
But better be careful than sorry now that u know
神桌背後為房間
如果是夫妻房將會導致離婚或是口角
如果是藉於16-60歲未婚者將會影響其感情生活
甚至會有晚婚或是不婚之情形
此房間適合居住是16歲以下60歲以上之人
但須注意床尾或是床頭都不可朝向神桌!!
會嚴重影響健康!!
In addition...
位於神桌後方之房間,床位之擺設須特別注意;
除了床尾不可朝神桌,造成不敬之效應外
床頭更不可以靠神桌這邊之牆面,
其效應會有噩夢連連、腦神經衰弱、中風、血症...等。
化解之方式除調整床位外別無他法,
如果貴宅有此種情形,建議速速調整床位或是更換房間
才能得以化解。
另外神明廳後方之房間在使用上有很多忌諱,
所以如果家中房間夠使用,此房間建議拿來當作書房會較好。
不建議當臥室使用
Edited by swift
神桌背後為房間
如果是夫妻房將會導致離婚或是口角
甚至會有晚婚或是不婚之情形
但須注意床尾或是床頭都不可朝向神桌!!
會嚴重影響健康!!
In addition...
除了床尾不可朝神桌,造成不敬之效應外
床頭更不可以靠神桌這邊之牆面,
Just for sharing.
My grandfather was not a believer of fengshui.
His bed shared the same wall as the altar.
When he slept, his head faced the direction of the altar.
In his early years, my grandmother had constant arguments with him.
She was beaten up by him when he wanted to get concubines.
He still went on to have concubines anyway.
My grandma died of diabetes and multiple cancers. Suffered for many years.
My grandpa got a stroke and suffered 9 years before his passing on.
Not sure if that's their karma or the impact of wrong fengshui. :dunno:
神桌背後為房間
如果是夫妻房將會導致離婚或是口角
甚至會有晚婚或是不婚之情形
但須注意床尾或是床頭都不可朝向神桌!!
會嚴重影響健康!!
In addition...
除了床尾不可朝神桌,造成不敬之效應外
床頭更不可以靠神桌這邊之牆面,
化解之方式除調整床位外別無他法,
才能得以化解。
不建議當臥室使用
Is there any other solution? My old father is too sturborn to listen to shift altar.
No other way to shift bed.
床頭does not 靠神桌這邊之牆面, it is at opposite wall.
神桌這邊之牆面 got a book shelf and study desk to block - Is 床尾 still consider 朝神桌?
Is it okay if head does not 朝神桌.
Is it okay if 床頭靠windows?
Hi Swift, where did you find this chinese info.
In end year den move out. I can draw upload picture of room
Edited by dean
proposed solution feasible?
altar table with a partition behind. But there is a little 0.5cm gap.
nvm, i can sleep to master bedroom.
