Mun & Rebecca & Enen's New Home
  • Replies 106
  • Views 21.8k
congrats!
err....how old is the flat, how big ar? How come no attached bathroom for one of the room to be known as MBR?
Sorry, now then see ur post aft browsing thru old postings :P
This is a super old flat. think >30 years liao :faintz:
But good location lor.
Hi folks, my fren has confirmed with Alan. Start date is set on 10.06.09
The reno items are as follows:
A. HACKING WORK
Hack off existing floor tiles **** & 3 bedrooms
Hack off existing floor tiles & wall tiles at kitchen & 2 toilets
Hack off 4 door frames
Dismantle false ceiling at bedroom entrance
Dismantle kitchen cabinets, living hall cabinet & 1 wardrobe
B. MASONARY WORK
Supply & lay 600x600mm polished homogeneous tiles **** &
3 bedrooms c/w skirting (tile: S$3.00)
Supply & lay 300x300mm homogeneous tiles at kitchen floor
Supply & lay 300x450mm wall tiles at kitchen to ceiling height
(tile: S$3.00)
Supply & lay 300x300mm homogeneous tiles at 2 toilets
Supply & lay 300x450mm wall tiles at 2 toilets to ceiling height
(tile: S$3.00)
Supply & lay waterproof membrane for 2 toilets
Construct shower kerb in bathroom + kitchen
Construct kitchen cabinets base, top plaster with cement & skirting
with tiles
Contruct fridge base & washer base with tiles
Construct beam & hollow block top bedroom door
C. PLUMBING /SANITARY WORK
Install a W/C sitting bowl
Install a basin
Supply & install stainless steel pipe for whole unit
Supply & lay pvc drainage pipe for sink & washer
Supply & install S/S rubbish chute
D. Wrought Gate
Supply & install wrought iron gate
E. DOORS
Supply & install 3 classic doors for bedrooms
Supply & install a Nyatoh solid main door (non-fire rated)
Supply & install 2 sets of aluminium frame with acrylic panels
bi-fold door for 2 toilets
Supply & install 4 wooden door frames for bedrooms
Supply & install 10mmT tempered glass swing door at kitchen
F. PAINTING
Supply materials & labour to paint whole units, including ceiling
& door frames & pipes with ICI/Nippon emulsion
G. CARPENTRY
Supply & install 36 ft kitchen cabinets, L-shape with solid ply wood
laminated finish + ABS trimming doors
Supply & install solid surface table top, L-shape 16 ft
Supply & install a 10ft TV console & feature wall **** room
Supply & install a 3ft shoes cabinet (half height) next to main door
Supply & install a 3.5ft sideboard in living room
Supply & install a 10.5ft casement door wardrobe at corridor
bedroom
Supply & install a 6ft casement wardrobe in bedroom 2
Supply & install a 10ft L-shaped casement wardrobe in MBR
(c/w pull-out dressing mirror)
Supply & install a 3.5ft TV console & feature wall in MBR
H. CLEANING & HANDOVER
Clear all debris
Lay protective cardboard over new floor tiles
Acid Wash
Total: S$30,000
(maybe adding more items, so think should be slightly higher:P)
Edited by rdnest
wah... mm so much more carpentry than me.. but add 5k only... *sob* I should have done some.
Congrats to your friend!!
Tiles for the whole house has been chosen from Sin Lek Building Materials P/L at 70 Eunos ave 7.
The salesperson, Jasmine was very helpful and friendly.
Glossy tiles for living & bedrooms
1st tile from top is for Kitchen floor. 2nd for kitchen wall (abit wave surface)
The rest not selected. for show nia :P
Bathroom tiles. All will be in white (same design) but only the shower area has a row of yellow with 2 strips of mosaic running along at 2 sides of yellow.
Toilet tiles. All will be in white (same design) but only the wall facing the toilet door has a row of green with 2 strips of mosaic running along at 2 sides of green. The picture is not so clear to show the shimmering glitters in some of the green mosaic. very pretty :)
Edited by rdnest
The white one is the wavy kitchen wall tile + orange tiles that will only for the wall between top& bottom kitchen cabinets. So it means no need to do backsplash...save $$ :P
Closer look of the orange tile
actually after choosing the tiles, my fren wants to change the layout...yet again :faint:
Alas, he can't help but feeling strange w/o a storeroom. Initially he planned to make one at one corner of the kitchen. It was later replaced by the cooking hob after the advice of FSM. Now, he hope to make one directly opp the hob. meaning the washer & dryer hv to give way and re-settle at middle of kitchen. washing basin thus got to make against chute wall so as to make more walking space rather than L-shape.
And L-shape wardrobe in MBR is also scrapped as he wants more space in MBR so tt his bb gal can bunk in (with her bb cot). His workdesk is tucked in a corner of his bb's rm. not custom made. think should be getting one from ikea or somewhere...
here is, (hopefully) the final plan :
Yalor. me see liao oso super heart bang :bangwall:
Why my reno so much earlier? :bangwall::bangwall:
nice choice of colours
thanks :P
his colour is mainly white/light colour tone. so use abit of loud colour to bring some life :)
Just done up a 3D layout for the kitchen. :paint:
This shows the Un-L washing basin. straighten up looks more neat or not :P
Below cabinet cannot hv drawers type cos got rubbish chute inside :unsure:
This show the newly added store area. The program dun hv sliding door selection, me use tall cabinets to illustrate.
Most likely the area will be built-up & using folding doors.. cheaper
Edited by rdnest
oso the washer & dryer will b stacked up, instead of side-by-side to save floor space.
Just to update: Dismantiling started on 10.06.09 and hacking started on 11.06.09...
Uploading of hacking work pictures soon :)
So many cabinet?? Your frnd not using hood?
mmm sounds fast... so by today should have finished hacking and can clear tmr? :)
