werty
A&g's Home
Dear all...
Getting my place in 2 months time so decided to start T-blog to share and get ideas for the reno. Reno will be little tho(kitchen, 2 toilets and the bedrm's wardrobe). Flooring will not touch (keeping the existing granite living and parq bedroom). Will try upload the current condition pics the soonest....stay tune....:)
Below is the items i need to do up.....
1) Hacking works:-
Hacking off existing wall & flr tiles in kitchen area.
Hacking off existing wall panel & door frame at kitchen entrance.(2900mm)
Hacking off existing wall & flr tiles in both common toilet area.
Hacking off existing door frame at both common toilet area.
Hacking off existing bath tub, toilet bowl, vanity top, shower screen at all toilets.
Dismantile whole house existing carpentry built-in works.
Haulage & clearing debris.
2) Masonary Works:-
Labour to smooth Hacked surface at kitchen area
Supply & lay Homogeneous Flr Tiles at kitchen area (max $4/-psf)
Supply & lay Design Ceramics Tiles at kitchen wall (full height)
Construct kitchen cabinet base with side tiles finishing
Supply & lay Homogeneous Flr Tiles at both toilet area flooring (max $4/-psf)
Apply chemical water-proofing for both toilet
Supply & lay Design Ceramics Tiles at both toilet wall (full height)
3) Plumbling Works:-
Kitchen area:
Supply & lay conceal all water pipings
Supply labour to install kitchen sink, washing machine piping
Supply labour to install kitchen accessiories
Master & Common toilet:
Supply labour to install toilet accessiories
Supply labour to install toilet bowl & wash basin
4) Capentry works:-
Living & Dining area:
To Fabricate L1300mm partition with desgin at foyer area
To Fabricate L1700mm shoe cabinet cum settee at foyer area
To Fabricate L1800mm tv console with desgin using solid ply laminate finishing
To Fabricate L1800mm wall feature cum display at tv area, solid ply laminate finishing
Bedroom 2 & 3:
To Fabricate L1500mm sliding wardrobe, solid ply laminate finishing
To Fabricate L2100mm sliding wardrobe, solid ply laminate finishing
MasterRoom:
To Fabricate L2400mm sliding wardrobe, solid ply laminate finishing
To Fabricate L1500mm tv console, solid ply laminate finishing
To Fabricate L1800mm wall feature, solid ply laminate finishing
Kitchen:
To Fabricate top kitchen cabinet with 2panel glass dr (8ft)
To Fabricate bottom kitchen cabinet L'14ft
To Fabricate L'14ft solid surface top
To Fabricate L'5ft solid surface top with storage cabinet
5) Ceiling Works:-
Supply & construct false ceiling at foyer and living
Supply & construct false ceiling L-box at dining area
6) General/Misc. Services:-
Supply labour to whole house painting using ICI emulsion paint
Supply labour to revanish exisiting flring (parquet & granite)
Supply and install white powder coating aluminium window with tinted glass (yard)
Supply and install white powder coating aluminium grille for whole house
Supply and install H'4ft x H'8ft wrought main gate
Supply and install H'6ft x H'6ft shower screen at both toilet
Laying floor protection
Electrical
So far been to 2 ID....sky high quotes...
Now considering "The Best Contractor in Renotalk...Best in SGP, some says batam..." Uncle Soon (thanks Simei Xiaomei for the contact)..however, the concern is he is too busy le....can handle any more project?
2nd would be the up and coming Mr Yeak....
Anymore Good ID/contractors to intro??...
Wondering is $25k suffi?...Welcome all ideas and recommendatons.....
Cheers.....
WELCOME!!!
:o wow...barely a min i post u reply...thks..thks...
I notice your signature got uncle soon's link....however cant access thru it....hmmm.....
Welcome!! Heard my name so I popped by.. :) source for a few quotes before you decide ba. He is indeed busy but if you don't mind spending a little more time, he does give a good price. :)
