Where To Buy Chrome Pipes Pls?
Hi There,
I intend to use a chrome bottle trap for my common toilet and it will be exposed under the sink. I understand most pipes connecting to the bottle trap will be pvc. If I want to match the chrome bottle trap, does anyone know where can I buy the matching chrome pipes please? Many thanks.
Hi There,
normal neighbourhood hardware shops and homefix dun sell - we had to get ours fm sim siang choon - got a stainless steel one. asia excel/hoe kee sells the chrome ones
Thanks beany for the prompt reply.
I have been lurking around for awhile and saw your blog. Very nice house you got there :)
I suppose stainless steel one should be better than chrome right?
thanks for the compliments :)
well.... guess s/s ones should be better - the plumbers actually proposed PVC as a more lasting pipe, cos not so prone to corrosion as chrome. but the wife din like the PVC thing, so die die went to source for s/s piping.
but actually, dunno how hardy the chrome bottle traps and pipes are agst corrosion, esp if you plan to use those drain cleaners in case of clogged pipes. if poss, try to get the more heavy-duty ones.
the bottle trap we got was of thicker material, so as the s/s piping.
but cos the s/s piping cannot be cut, unlike chrome, there is still PVC joining @ the bottom... tt is the sad part :(
Just curious, how come the stainless cannot be cut? The bottom joint, if the stainless pipe diameter bigger than the plastic joint then it will look nice rite?
